Need a new set of tires - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #11 of 67 Old 03-14-2019, 08:13 AM
First, don't be surprised if you realize the Battlewings are actually one of the best tires you can run on the V STrom. You can drag the $%^&*(# frame half in two with them as far as how they stick on pavement. ( You still won't keep up with the crotch rockets! ).
I am running the T-31 Bridgestones on the RT. We have run their predecessors on the Super Tenere and the 650 V Stroms. Again, there is no limit to the traction that will keep you from dragging hard parts on the bike. And still have reserve.
I have run the PR3 and PR4 on teh 2012 650. Good tires, but wear wasn't all that good either. Bought them after drinking the Kool-Aid that they were such long wearing tires.
ANY tire you run will squirm on tar snakes. Some will wear funny. Some will hit a patch of something loose on pavement and you will swear they are worthless.....when any tire will slip in that case. Street tires do tend to ride a bit smoother than the Battlewing, as the Battlewing has a stiff sidewall and tread area.
It comes down to a tire you trust. A tire that doesn't scallop badly feels good through its life. They all flat spot when run thousands of miles on interstates. American Moto Tire has Bridgestone T-31 in V Strom sizes for $238 shipped. Everyday price. These wear good, as well as most other tires. They wear more evenly than most tires. They stick and have a really good feel when pushing them hard in turns. Never had any issue in the wet with them.
Speaking of wet traction, my personal beef with those that claim the Michelin tire is the best in the rain confuses me. How did they arrive at that statement? Did every other tire spin out or slide across three lanes of traffic in wet conditions? Cause I have run several brands over the past few years and simply have never had a tire slide out on the wet. I even test wet traction with a rip on the throttle and clutch to get a feel for the pavement....and still they stick. I think about all tires you buy today are really good tires all around....
dravnx and V-Strom Ry 2 like this.
realshelby is offline
post #12 of 67 Old 03-14-2019, 08:20 AM
I run the A3 specifically because it has excellent performance on the Northwet's slick mossy roads. Not to mention some brands of white road paint absolutely suck when wet because it's so slippery. Mileage? 10k+. Gravel road? No problem, air down to 20 and float.
Hatchi is offline
post #13 of 67 Old 03-14-2019, 09:38 AM
Highwayman2016's Avatar
I've also had good luck with the Shinko 705's. If you are money conscious they deliver, 10,000 on the rear and $165 for a set.
Lrobby99 likes this.
2014 650 Strom
Highwayman2016 is offline
post #14 of 67 Old 03-14-2019, 09:40 AM
Originally Posted by Highwayman2016 View Post
I've also had good luck with the Shinko 705's. If you are money conscious they deliver, 10,000 on the rear and $160 for a set.
On the DL 1000 I would get 3500-4500 miles from the rear 705!
I did buy more than one set at $100 per set delivered. The good ole days!
chirosyd likes this.
post #15 of 67 Old 03-14-2019, 11:00 AM Thread Starter
Null 13's Avatar
@realshelby : I like the T31, the back tire grips good and got a 3(rear) to 1(front) ratio on tires, which is good. The T30s gave me a 2 to 1 ratio, and were quite good in corners too. I don't really care that much for wet handling, as i will get into "rain mode", cut on speed and angle of turn. In other words, i don't trust any tire in the wet, so pretty much anything better than a bare rim should be fine for that (lol). In the current matter, i'm looking at which tire could give me better mileage and cornering than the T31s for a minimal increase of budget, while the sale is on.
And now... i realize i didn't post which tires i have on the bike at the moment... Bridgestone T31... sorry!
You guys freak me out with your high mileage results
705s aren't an option, at least not for now, i need something more street oriented.
________
2014 VStrom 1000 Adv SE, because army bikes are more adv
Null 13 is offline
post #16 of 67 Old 03-14-2019, 11:18 AM
Tire wear min tread depth 1.5mm
Hatchi is offline
post #17 of 67 Old 03-14-2019, 11:23 AM
Spec's Avatar
Yea the mileage some get...
I use Shinko 712s. Cheap and work great for me. 90/10 type tires.
They're fine on dry dirt too.
I get my normal mileage out of the rear but for some reason the front doesn't seem to wear at all. Typically I get 2 rears to one front (with other tires). I changed out the 712 front after 3 rears just cause I thought I should but it still looked good.
Spec is offline
post #18 of 67 Old 03-14-2019, 11:29 AM
Fox
Fox's Avatar
You sir, just made my choice, a harder one.
Is it true that the A3 is a little softer and more vulnerable to puncture?
I've gotten screws and nails in just about every rear tire I've had, so I don't know if the design is to blame. Sheet metal screws are great at working their way in.
I keep a plug kit and compressor under the seat, because it's only a matter of time before it happens again.
Fox is offline
post #19 of 67 Old 03-14-2019, 11:34 AM
Spec's Avatar
I replace tires when they hit the wear bars.
I figure that's what they are there for!
Unfortunately I wear the middle out long before the sides. Would be great to live somewhere that that wasn't the case!
Spec is offline
post #20 of 67 Old 03-14-2019, 11:36 AM
Not sure what this adds to the conversation.
2014 650 Strom
What would you do? Replace these tires in 100 miles; or 662 miles? arooni V-Strom Service and Maintenance Questions and Discussions 23 09-11-2011 04:29 PM
Thoughts on car tires for bikes Scott E. Bonds V-Strom Service and Maintenance Questions and Discussions 17 07-09-2011 11:39 AM
Tourance tires mounted, change in handling stevet General V-Strom Discussion 15 07-02-2008 03:16 PM
Talking About TKC Tires Black Lab General V-Strom Discussion 3 05-08-2008 10:13 PM
