Tires 170-60R17 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By Null 13
post #1 of 10 Old 03-12-2019, 02:41 PM Thread Starter
Gerardo Aguilar's Avatar
Tires 170-60R17
Hello, someone could comment about the tire Michelin Anakee 3 , size 170-60R17 if i can use it in the rear of 2014 suzuki v strom 1000, because is bigger than the oem sizes, will i have some trouble
or restrictions to look after ( OEM SIZE IS 150-70 R19 )
thanks
aguilar g. :
Gerardo Aguilar is offline
post #2 of 10 Old 03-12-2019, 03:53 PM
Spec's Avatar
thanks
aguilar g. :
Tire Size Conversion Calculator
You shouldn't have clearance problems. The 170 is a bit less than an inch wider and about the same taller.
Spec is offline
post #3 of 10 Old 03-12-2019, 06:16 PM
blaustrom's Avatar
It should mount ok and have enough clearance but it will upset your ABS and Traction control.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 10 Old 03-12-2019, 09:01 PM
Null 13's Avatar
How would it upset them though? I have 160s and no problem.
That being said, i would love to slap on some 170s, will look in this thread for confirmation before ordering new rubber for the end of the month.
________
2014 VStrom 1000 Adv SE, because army bikes are more adv
Null 13 is offline
post #5 of 10 Old 03-12-2019, 09:37 PM
Spec's Avatar
Less than an inch larger diameter would wack the computer you think?
Don't know but I doubt it's that sensitive. One way to find out.
Spec is offline
post #6 of 10 Old 03-12-2019, 11:31 PM
blaustrom's Avatar
When I was running the 195/55-17 last year all was well whilst that tire was new. Towards the end the TC would kick in in 6th gear on the interstate and ABS would shut down after a few miles. The only explanation for that was the off size tire I was running. I have not ridden the bike since so there is the off chance that there is an unrelated issue. If so I will post that once we can get the bike back on the road.
Blau2 2014 DL1000A
post #7 of 10 Old 03-13-2019, 12:28 AM
Null 13's Avatar
That's a car tire though.
Big B and alfie53 like this.
________
Null 13 is offline
post #8 of 10 Old 03-14-2019, 02:13 PM
The ABS system must have some leeway built-in with respect to revs/miles front-to-rear to account for normal tread wear, i.e., you mount a new rear with full-depth tread matched to a worn front at wear-bar depth. Prolly no way to quantify the fudge factor built in by the factory engineers, but I'd guess a 1-2% variance from stock would be acceptable without tripping the ABS warning.
badjuju is offline
post #9 of 10 Old 03-16-2019, 08:34 PM
JustAnotherDude's Avatar
I can't see how you'd have any issues with fitting it or with the system. Assuming the same profile on both tires, using the converter in post #2 the 170 is shorter, not taller, but only by 6mm. Tire circumference is less than 20mm smaller on the 170 (2016.3mm vs 1997.4mm), that's 0.9%. Since all the speedos report fast, it will be ever so slightly faster than on the original tire.
JustAnotherDude is offline
post #10 of 10 Old 04-01-2019, 06:22 PM
Null 13's Avatar
Just making sure before i order, are we saying a 170-60-17 would fit on a 2014 Vee2?
No rubbing on the sides?
________
Null 13 is offline
What would you do? Replace these tires in 100 miles; or 662 miles? arooni V-Strom Service and Maintenance Questions and Discussions 23 09-11-2011 04:29 PM
Thoughts on car tires for bikes Scott E. Bonds V-Strom Service and Maintenance Questions and Discussions 17 07-09-2011 11:39 AM
Tourance tires mounted, change in handling stevet General V-Strom Discussion 15 07-02-2008 03:16 PM
Talking About TKC Tires Black Lab General V-Strom Discussion 3 05-08-2008 10:13 PM
