Tire options. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 10-10-2018, 12:55 PM Thread Starter
TinyBear's Avatar
Tire options.
Looking like I will need new rubber early next season for my 2017. Id like to buy in the off season to save a few $$$.
I do a good mix of paved and gravel roads but absolutely zero off road work as I have small bikes for the trails. Next summer I am planning a ride up the James bay road which is paved but is Ruff and some of the riding we will be doing is several hundred Kmís of gravel.
Tires Iím considering are the Mitas E07. Or the radial version of the Shinko 705s.
Just wondering if any one here has tried either or has better recommendations for my projected use.
Have had Metzler Torranceís on my 07 Strom and disliked em especially in the rain. The stock batlax tires on my Strom been pretty good but have squared off pretty quick. Realistically I can probly make the trip on then but would rather have fresh rubber in hopes of avoiding flats if at all possible.
2017 Suzuki V-Strom 650 XTSE
2010 Yamaha TW200
2016 Polaris Sportsman 450HO
2004 Suzuki Ozark 250
TinyBear is offline
post #2 of 6 Old 10-10-2018, 03:09 PM
Look at the new Metzler Tourance Next.. Very good reviews!
Also, Pirelli Trail Scorpion..
both tires are NOT for off-road.. Will be good for gravel.
BornToRide is offline
post #3 of 6 Old 10-10-2018, 05:59 PM
BC Rider's Avatar
Your point about having fresh rubber to avoid flats is the most important. The Shinko is a decent tire for $130 and the Bridgstone Trail Wing is a good Japanese made tire for 20 bucks more. They are quite similar tires though the Shinko is a bit more aggressive(and noisier). I ran Tourance front and back and found they were long wearing when they made them in Germany but wore quickly when they moved manufacture to China. This year I went back to the OEM Trailwings and they are excellent on the highway while still allowing me to cruise the forestry roads.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #4 of 6 Old 10-12-2018, 09:32 AM
Been riding 20 years, never had a flat, until last week. Found a paper clip type wire in the tread groove of my tires, which have 2500 miles on them. Will new rubber help avoid flats, i suppose, but not always. I suppose if theyre really worn.
2016 DL1000 ABS
ERockJL is offline
post #5 of 6 Old 10-12-2018, 09:50 AM
Highwayman2016's Avatar
Tire options.
Iíve had good luck with the radial Shinkos on my 2014 650. They do make some noise. Work well in the rain as well. At least in Tropical Storm Bud last June riding through Colorado.
2014 650 Strom
Highwayman2016 is offline
post #6 of 6 Old 10-14-2018, 12:06 PM
Motor7's Avatar
The E07 Dakar has a thicker sidewall(capable of running flat for short distances), & gets great wear mileage(10K ish). They can be a bear to mount if you are mounting them yourself though.
'15 DL650XT
Motor7 is offline
anakee III sbeadg Suspension and Tire Tech 273 04-26-2017 12:32 AM
New Tire Option-Shinko 804/805 IdahoRenegade Suspension and Tire Tech 113 10-30-2016 06:13 PM
Rear Tire Life Expectancy? RobG DL650A - 2012-2016 67 02-05-2015 02:33 PM
Tire Repair Kevin D General V-Strom Discussion 42 11-13-2014 10:54 PM
Help!! Attempt at Tire replacement SquidWilly V-Strom Service and Maintenance Questions and Discussions 36 03-24-2013 08:14 AM
