Ran on a low/flat rear tire - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 11Likes
post #1 of 25 Old 10-06-2018, 10:25 PM Thread Starter
This is my first bike, be kind! I ran about 17 miles on my newish shinko 705 while it was nearly flat. I knew something wasn't right as it kept wandering back and forth. Got off at the next exit and the tire and wheel were both very hot. The valve core was loose, so I took it out and replaced it with a new one from the truck stop.
I'd been losing a psi or two over night and thought it was normal. I topped it up this morning.
Is it safe to continue riding on this tire? It's a radial tire.
GunStrom is offline
post #2 of 25 Old 10-06-2018, 10:35 PM
As long as you have air you can ride it. I rode several miles in the mountains with a flattening 705. I wanted to get to a point I knew was level to do a tire plug. Chip seal on an old tire poked a hole.
I rode another 5 miles on partial air to a gas station to fill it properly.
Some folks ride out a tire even with a plug as get full life out of the tire.
The BMW CHP bikes run on run flat tires. They pick up debris quite often.
post #3 of 25 Old 10-06-2018, 10:43 PM Thread Starter
It was pretty much flat when I got to the gas station. I was doing about 70 on the interstate for about 15 miles. I bet those run flat tires are stiff!!!
GunStrom is offline
post #4 of 25 Old 10-06-2018, 10:45 PM Thread Starter
The tire and wheel were both extremely hot. The reason I pulled over was because of the wandering, if I had known it was a flat tire I would of stopped immediately.
GunStrom is offline
post #5 of 25 Old 10-06-2018, 11:10 PM
blaustrom's Avatar
Extreme heat is not good for the tire. It may not have the strength as per its original design.
Are you saying that the tire is loosing pressure AFTER the ride or did it loose already before?
I once pretty much destroyed a tire that blew out on the interstate at +70. It also was extreme hot, you could not touch it. When it came off there was like charcoal inside. Based on that experience I would get a new tire. Your life depends on these 2 black rings.
I have no problem plugging a punctured tire and riding it for many miles but your case may be more serious.
Big B likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 25 Old 10-06-2018, 11:18 PM
Brockie's Avatar
Check the sidewalls carefully for any sign of cracking or damage where the rim has sat on the sidewall. I honestly doubt that you could do anywhere near that speed on a tyre with zero pressure, so it still must have had some pressure in it - and that would dramatically reduce the likelihood of physical damage.
It would have got very hot but still may be fine to use. Best to inspect it often for the next 1,000 miles.
Brockie is offline
post #7 of 25 Old 10-06-2018, 11:30 PM Thread Starter
The tire lost a small amount of air before this incident. Holy shit, were you alright?
At 90 bucks for a tire, I don't have a problem replacing it.
GunStrom is offline
post #8 of 25 Old 10-06-2018, 11:33 PM Thread Starter
Other than the middle losing quite a bit of rubber, it looks normal. When I tried reading the pressure, it read zero and no air escaped like it normally does when you read the pressure.
GunStrom is offline
post #9 of 25 Old 10-07-2018, 07:53 AM
locoblanco's Avatar
You should remove the tire and visually inspect the inside. I have seen tires run low that looked good but inside there was shredded rubber. It may seem like a lot of trouble but as blaustrom said, your life depends on this.
Mulewright and scab like this.
locoblanco is online now
post #10 of 25 Old 10-07-2018, 08:59 AM
cndstrom's Avatar
inspect inside of tire!
I agree with above, I use tubliss on my enduro bike and run very low pressure. The inside sidewall goes all to crap and the outside still looks good. I'd replace the tire if the sidewall even feels softer.
scab likes this.
cndstrom is online now
THE Tire Thread MightyShep Suspension and Tire Tech 1012 08-17-2019 01:20 AM
Mixing trail/road front tire with pure road rear tire bajakirch Suspension and Tire Tech 2 06-26-2018 09:45 AM
Rear brake wobble after rear tire removal tsg Maintenance, Tech and Products. 15 06-10-2017 01:29 PM
Anyone willing to help change rear tire in Colorado, northeastern Utah, or southern Wyoming? Adventurefiend Midwest 1 08-02-2016 07:32 PM
Rear tire for on/off mix Teskio Suspension and Tire Tech 23 01-22-2016 04:10 PM
