Bizarre tire wear - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 39 Old 08-18-2018, 09:25 PM Thread Starter
Bizarre tire wear
This is the front tire of my '08 Wee. This wear developed over the course of a several thousand mile trip. There was a little bit of evidence of oil leaking from one front fork, so I'm replacing the seals (my attempts to clean out dirt from the seals didn't find anything). I have no idea how old the fork oil is.
I've never seen anything like it -- each tread block is worn at the trailing side, but much thicker on the leading edge. It's the same all the way around the tire.
Secondary question: how dangerous is this?
Topher Eliot
Will someone please tell my lower back that I'm 'Junior'?
tgeliot is online now
post #2 of 39 Old 08-18-2018, 09:35 PM
That front is done, looks like a bad belt or something.
BrianS likes this.
post #3 of 39 Old 08-18-2018, 09:37 PM
Air pressure is often the cause of weird tire wear. The lack of any cornering is evident too. You still have all the sprues on the outer tread block.
Big B likes this.
post #4 of 39 Old 08-18-2018, 10:26 PM
bighammer's Avatar
Mine feels like it's worn that way. Hard braking maybe?
pvwheeler likes this.
2018 Flee-Strom 1000XT
bighammer is offline
post #5 of 39 Old 08-18-2018, 10:56 PM
K9 Wee's Avatar
Suspect that the leaking fork may have contributed....toast tire!
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 20L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #6 of 39 Old 08-18-2018, 11:19 PM
My forks were puking from St Paul back to LA and had no weird tire wear.
post #7 of 39 Old 08-18-2018, 11:48 PM
Coach23101's Avatar
Location: Seattle in the summer and East Cape, Baja in the winter. Perfect!
If you didn't feel much while running it has got to be a bad tire like Big B said. Take it to a tire shop (any) and see what they say. They probably have seen similar distortion / wear.
Coach23101 is offline
post #8 of 39 Old 08-19-2018, 01:37 AM Thread Starter
Unlikely that it's due to hard braking, I'm a pretty moderate rider.
Topher Eliot
post #9 of 39 Old 08-19-2018, 07:42 AM
locoblanco's Avatar
A blocky tread like that tends to wear unevenly on pavement. Might still be ok for dirt or low speed pavement, but higher speeds, like 50mph+, could result in a dangerous wobble.
locoblanco is offline
post #10 of 39 Old 08-19-2018, 01:18 PM
TAC PRO's Avatar
Were you riding in high crosswinds?
www.tacpro.com
TAC PRO is offline
