It this cupping? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 16 Old 05-07-2018, 01:21 PM Thread Starter
vanislejay's Avatar
It this cupping?
Noticed this strange wear on my front Anakee-2 this morning. I need a new tire, but it's a bummer because there is plenty of use able tire left there.
Is this cupping and is this a normal cupping pattern on an Anakee-2?
vanislejay is offline
post #2 of 16 Old 05-07-2018, 01:47 PM
Cupping or feathering. Those were known for that. Doesn't mean the tire has to be removed. might make some noise or a bit of a vibration at certain speeds. More air pressure can lessen the development, but there is a tradeoff there too.
Big B, V-Tom and Brockie like this.
realshelby is offline
post #3 of 16 Old 05-07-2018, 02:15 PM
erci's Avatar
Yup. That's gonna make it feel funky at slow speeds and comping to stops. I remember asking myself "did I forget how to ride?" when my tire looked like that! hahah
erci is offline
post #4 of 16 Old 05-07-2018, 02:20 PM Thread Starter
vanislejay's Avatar
Ok, good to know I can run this one out a bit longer. I wasn't expecting that in the slightest, thanks!
post #5 of 16 Old 05-07-2018, 02:20 PM
RCinNC's Avatar
Yep, that's what it looks like. My front Shinko 705 is even worse; the knobs are starting to look like the teeth on a meth addict.
pvwheeler, Spec and erci like this.
RCinNC is online now
post #6 of 16 Old 05-07-2018, 02:28 PM
VSrider's Avatar
Every front tire I've had on my Strom has cupped. Lose about 20% of the life of the tire because of it.
VSrider is offline
post #7 of 16 Old 05-07-2018, 02:44 PM
Fox
Fox's Avatar
I run my fronts at 42psi, they don't seem to cup that way. You should check out the Anakee 3 as a replacement - they improved quite a bit over the 2.
Fox is offline
post #8 of 16 Old 05-07-2018, 03:10 PM
erci's Avatar
Whoa that's high. Isn't 36 what's recommended? At 42, the tire probably never fully warms up which means you have less traction in turns. It also means you have less grip when you fully apply the front brake, because it's not heating up and also because it can't compress as much to expand the contact patch.
Test it for yourself. After a ride (at 42psi), put your hand on the center of the tire and see how warm it is. Then try similar ride at similar ambient temperature at 36psi. Should feel a lot warmer to the touch.
I try to save money any way I can, but never at the cost of grip / safety.
Spec and 2thDr like this.
erci is offline
post #9 of 16 Old 05-07-2018, 06:13 PM
STCorndog's Avatar
Normal, run it until the front end starts shaking enough to bother you.
realshelby and VSrider like this.
STCorndog is offline
post #10 of 16 Old 05-07-2018, 07:23 PM
Hard miles's Avatar
Many people will disagree but ... flip it. On my Vee I remove the wheel and simply flip it. The nay sayers will say but that is going against the tire indicated rotation. My answer is slow down on wet roads. Dry roads no issue, dirt roads I slow down.
My tourances didn't cup but my k76's did.
Hard miles is offline
