front forks and rim bent on 07 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 22 Old 05-01-2018, 01:57 PM Thread Starter
woodenkayaker's Avatar
Unhappy front forks and rim bent on 07
Alright, Im ashamed to admit it but I bent my bike.
approx 40km/hr impact under full throttle with an immovable object. left quite the bruise!
currently not working due to health issues (unrelated) and want very much to try to get the bike back on the road. Its not worth much, but hey its my first bike!
dealer wants 3k for two forks and a rim...
have been reading a lot on here (and everywhere else) that the suspension seems to be the weakest link on the bike.
If im going to have to drop money, why not make improvements at the same time?
very mechanically minded, but new to bikes.
found a wrecked bike/salvage yard that can get used parts for 1 grand...are there better options on a budget?
really appreciate the help, and any motivation I can get at this point.
THANKS!
woodenkayaker is offline
post #2 of 22 Old 05-01-2018, 04:11 PM
If the tubes are the bent part, those are available for about $400 American. seals and bushings are gonna be a bit more.
A rim should be a couple hundred used.
Your fork upgrades are going to be even more.
You don't have to apologize for having a bike Boo-boo, some of us are quite accomplished at that.
iamsmiling and woodenkayaker like this.
post #3 of 22 Old 05-01-2018, 08:41 PM Thread Starter
if the tubes are bent...can the internals be salvaged??
post #4 of 22 Old 05-01-2018, 09:45 PM
I had to put one of my forks in a 20 ton press to straighten it enough to get the spring out. So somes of the parts may not be destroyed.
I reused the bushinging because to my untrained eye they looked ok and I'm a cheap screw.I'm pretty sure I put in new seals and dust covers and fork oil.
The Black Lab tutorial leads the way to success.
https://blacklabadventures.com/
THere are guys that straighten rims too depending on how tweaked they are.
Actually depending on how bent the forks are they can be straightened also. If you see a visible crease in the tube it's trash time.
woodenkayaker likes this.
post #5 of 22 Old 05-01-2018, 10:25 PM
like notacop said. look for some one that can straighten it out. call some frame shops in your area
Robert CB Schmaltz
14 Vstrom 1000
09 Connie
14 Versys 650
13 KLR
14 CRF 250 L
05 Shadow 1100
08 WR 250
05 Vrod
75 Z900 Kaw
Ride2day!! is offline
post #6 of 22 Old 05-01-2018, 10:27 PM
blaustrom's Avatar
I think there was a post here recently about Italian made fork legs. Can't remember the price but less than OEM. May be worth searching for that info.
Also there are shops that do work on straightening out fork legs, depending on how badly bent they are. Again worth to research.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #7 of 22 Old 05-01-2018, 10:29 PM Thread Starter
Not a wrinkle, bent possibly 10 degrees or so? Visible anyway.
Rim is right wobbly...
My friend (whom I got the bike from) rode it after I bent it, did a wheels and the tire chirped like a plane landing when he finished... So there's definitely a problem with free rotation...
I'll try a frame place.. That's a great idea!
I just don't think I can fix it otherwise
Thanks guys!
Sent from my LG-H831 using Tapatalk
post #8 of 22 Old 05-02-2018, 12:38 PM
The post about the Italian made forks, that's what I got. Very convoluted. I ordered through Sasquatch but got shipped from a business in Calif, Socal actually.
It took several weeks because the supply chain is just like that.
Once upon a wreck the frame guy said that if the fork is only a little bent it's harder to get straight than one with a few degrees of oops.
Good luck. if the bike was rideable after with the bent fork, it ain't that far off and will cost a lot less to fix than new parts.
Motor7 likes this.
post #9 of 22 Old 05-04-2018, 09:13 PM
Motor7's Avatar
Motor7 is offline
post #10 of 22 Old 05-05-2018, 12:48 AM Thread Starter
Thank you for the eBay links... Are the 650 and 1000 suspensions the same? I've got a 1000.. I think I probably forgot to mention that.
It looks like I'll be rebuilding what I have or buying used. Possible upgrades to replace bent items...
You guys have been very helpful!
Frame shops and bike shops won't touch forks due to liability in my area, new are more then the bike is worth..
Rebuilding can get me better suspension then new parts...
Used items off eBay might be the way to go.. As a backup.. but it will be fun to pull the ones I have apart regardless!
