Fork seals again - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 16 Old 04-11-2018, 04:46 AM Thread Starter
Clayyalc's Avatar
Fork seals again
Suspension felt a little weird today and looked down to find this.
All after 2500 mile but there 6+ inches of snow coming so I guess I have some time to fix it.
2015 DL650
Clayyalc is offline
post #2 of 16 Old 04-11-2018, 11:02 AM
The forks get shiny with all that oil on the don't they?
The Black Lab tutorial helped me with a rebuild. https://blacklabadventures.com/
post #3 of 16 Old 04-11-2018, 12:58 PM
nvr2old's Avatar
Rancho fork boots will stop that problem.
Big B, notacop, Supatramp and 1 others like this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #4 of 16 Old 04-11-2018, 07:49 PM
Rolex's Avatar
Before you change the seal get a seal doctor and give them a clean, most times there is no physical problem with the seal there is just crud caught under the seating surface but do check for pits in the fork tube and clean them up if required.
Before you put the outer dust cover back into place get one of the green kitchen scourer, cut a strip off one edge. wrap it around the inner tube and put the cover back in place.
Depending on the type of ridding you do change it out every 3 to 6 months.
You should never see another seal leak as it cleans the fork tube and collects the crud before it can reach the seal.
V-Tom and Hank122 like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #5 of 16 Old 04-11-2018, 08:19 PM
PineLaneRider's Avatar
PineLaneRider is offline
post #6 of 16 Old 04-11-2018, 11:06 PM
marcham's Avatar
Camera film used to work great for cleaning seals...
Sent from my SM-T700 using Tapatalk
2015 VSTROM 650 X ABS EXP
marcham is offline
post #7 of 16 Old 04-11-2018, 11:48 PM
Hank122's Avatar
Had to clean mine last summer, used a plastic milk carton and cut it in the shape of the tool mentioned above. Worked the shiz!
Henry
"Rock bottom will teach you lessons that mountain tops never will..."
2016 V-Strom DL650 (red) 'Sweetness'
2011 V-Strom DL650 (white)
Hank122 is offline
post #8 of 16 Old 04-12-2018, 04:35 AM Thread Starter
Clayyalc's Avatar
It is sadly beyond cleaning. It failed pretty catastrophically. I might even need to replace the brake pad on the that side. Enough oil came out that is ran down the whole lower tube.
I've been meaning to get some. I can't even tell what really happened. There didn't seem to be anything under the dust seal. The grease that was left over from installation was perfectly clean. I kinda think seal was just defective.
2015 DL650
Clayyalc is offline
post #9 of 16 Old 04-12-2018, 07:17 AM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
Glad this popped up when it did.
Working on a buddies bike and it had a little sheen on fork, installed fork brace and it started dripping.
Fortunately I had calipers already moved as I was running Galfers lines so no fluid on brakes.
So I'm replacing seals and thought that seal doctor is sweet and would piss off my wife!
So Got it on order for future use
Also ordered Rancho shock boots to try and help prevent future leaks, but threatened him I was ordering the boots in Dildo pink
SO here is my question.
Do you see any long term issue with the green scrubby pad being inside the upper portion of the fork?
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #10 of 16 Old 04-12-2018, 07:35 AM
Rolex's Avatar
Mike for many years I used sponge rubber soaked in fork oil under the dust cover to help keep things clean on all my bikes (dirt & road), it worked great on dirt, mud and dust but dried up bugs were still a problem so I tried the scourer a year or so back and the results have been great.
With the V2 having upside down forks and fork guards I did not think the scourer would be required but I was wrong, I got a leak, the Dr and scourer took care of it.
I will continue to use it until it stops working or I think of something that I think may work better.
2014 V2, Snoopy
Rolex is online now
