04 dl1000 Rear Shock question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 02-06-2018, 01:08 AM Thread Starter
WildDoktor's Avatar
The hose that goes from the remote adjuster to the top of the shock: does it contain fluid or nitrogen or some other gas? Is it under pressure in any way? Or is it simply a mechanical cable inside a sheath?
WildDoktor is offline
post #2 of 7 Old 02-06-2018, 01:29 AM
I believe it holds oil. I think the adjustment knob compresses the spring via hydraulic pressure.
Mr Big Head is offline
post #3 of 7 Old 02-06-2018, 04:19 PM Thread Starter
WildDoktor's Avatar
Hmmm...so is it under pressure? The hose on mine needs replacing, so I'm wondering if I can do that with the shock installed in the bike, and if the entire reserve of oil is going to come squirting out at high velocity.
Guess I should search out the "shock rebuild" threads... :-)
post #4 of 7 Old 02-07-2018, 05:32 AM
It holds oil but only under pressure if it is wound in. Should be able to change the line insitu. Refilling is going to be a harder job tho. There is no gas charge on top of it.
Cheers Tom R
"No Fear" just means you are not going fast enouh yet. life begins when you get outside that comfort zone.
Current rides
18 Busa
14 Vee2
13 Husky TR 650 Terra
08 Busa(now sold)
07Vee1(now sold)
02 Busa (sold)
97 TLs
97 TRX
92 NSr
Current Projects
38 BSA Goldie
Upcoming projects,perhaps by the time I get retired just maybe
83 GSX11(gunna be bought forward now as I don't have a going across frame 4)
71 A100
tomrux is offline
post #5 of 7 Old 02-07-2018, 01:49 PM
Or have it rebuilt by Sasquatch for a reasonable price.
Adventure Power Sports, LLC
post #6 of 7 Old 03-12-2018, 03:23 PM
notacop. You have the work done on your rear shock? Looks like a nice alternative.I looked at Progressive rear for $400 plus but couln't quite "spring"for them. My rear damper never clicked.Just spun around .Did nothing.
DonStromer04 is offline
post #7 of 7 Old 04-18-2018, 05:52 PM
The spring preload adjuster is only under pressure when screwed in. You can replace it on the bike, but it would be a pain. If you have a non abs bike and a center stand it only takes about 30 minutes to get the shock off.
Replace the hose. When the hose is off the knob section, put it upside down in a vice or on the bench and unscrew the knob all the way. use a narrow screw driver to go down the hose mounting hole and press the piston back in. Top off the fluid with ATF and install the hose. If you dont have it fully bled, it is not a big deal.
APSEAGLE
aka: Sasquatch, the suspension guy
apseagle is offline
