GLEE Torque spec for ROD, REAR CUSHION 62641-06G00? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 02-05-2018, 10:21 AM Thread Starter
Title says it all. They're also knows as dog bones. Is there a website that lists torque specs for a 2012 DL650a? Thanks!
rambunkshuss is offline
post #2 of 2 Old 02-05-2018, 10:42 AM
See How much torque should I use on the bolts?
Specifically, the cushion lever rod (Suzuki's name for the 62641-06G00 dog bone link) nut torque is 56.5lb-ft.
I believe the generic chart would put it at 36lb-ft if I'm not mistaken about the size so It could be another of the suspect high torque values. If it is a 10mm shank bolt, I wouldn't go higher than 40lb-ft.
