Suspension shops Los Angeles? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 2 Post By realshelby
  • 1 Post By notacop
  • 1 Post By notacop
post #1 of 10 Old 01-13-2018, 11:32 AM Thread Starter
KSM
KSM's Avatar
My new-to-me 2012 650 has a pretty “bouncy” ride. I’m about 190 geared up. I am aware of ESP in La Crescenta and another dirt oriented place in Santa Clarita. Any other recommendations?
Thanks
Kyle
2012 DL650A (purchased Dec 2017)
2005 DRZ400S (sold Dec 2017)
1972 Norton Commando (sold 1984)
1978 Suzuki DR370 (sold 1982)
KSM is online now
post #2 of 10 Old 01-13-2018, 11:39 AM
Installing the parts that "fix" the suspension is rather straight forward.
Getting the correct parts and the correct guidance for installing them is still the biggest problem. Most "shops" are not really qualified to tell you exactly what you need. That takes research and they don't want to spend time doing that.
I would contact some suspension suppliers and ask what they recommend. Stuff like the cartridge emulators for the front forks, what oil weight to run in them and what other modifications need to be done to the forks when installing the new parts ( including springs ). Then there is the rear shock. When upgrading the front it can make the rear seem worse than it was. There are places you can send your stock shock off for upgrading ( Daugherty motorsports ) or you can buy any number of aftermarket ready to bolt on shocks.
Get those decisions and parts in order, then find a shop that will install them correctly. It just needs to be a shop that will do the job correctly and not make shortcuts.
Mulewright and KSM like this.
realshelby is online now
post #3 of 10 Old 01-13-2018, 12:42 PM
Hola, Kyle.
Not in the So Cal valley but Sasquatch in Idaho can help.
Adventure Power Sports, LLC
KSM likes this.
notacop is online now
post #4 of 10 Old 01-13-2018, 01:51 PM Thread Starter
KSM
KSM's Avatar
Good advice Terry, thanks. I agree that getting the right advice on parts is the most important. A few years ago, using the Racetech calculator, I replaced the front and rear springs on my old DRZ. After doing so I discovered the new front springs were way too stiff and went back to the stock ones. Simply a stiffer rear spring made a big improvement and the bike felt pretty balanced. I have tools and am capable of swapping things out. I'm also lazy and would kind of like to just hand the bike off to someone. I'll do some research and see what other advice comes up here. Cheers.
KSM is online now
post #5 of 10 Old 01-13-2018, 02:04 PM Thread Starter
KSM
KSM's Avatar
Interesting. Looking at the RaceTech calculator it is recommending increasing the spring rate, front and rear, by about 50%.
Front stock- .65 kg/mm
Front recommend - .917
Rear stock- 8.2
Rear recommend- 12.8
KSM is online now
post #6 of 10 Old 01-13-2018, 03:35 PM
Home - Motorcycle Service and Repair East Pasadena / Monrovia - West Coast GP Moto
They can do the mechanical installation when you order the parts. Pete and Alex.
KSM likes this.
post #7 of 10 Old 01-13-2018, 03:56 PM Thread Starter
KSM
KSM's Avatar
Thanks Greg. And I guess there's that guy in Glendale you mentioned...
KSM is online now
post #8 of 10 Old 01-15-2018, 11:48 AM Thread Starter
KSM
KSM's Avatar
Leaning heavily toward Daugherty Motorsports. Seems like a great option and the best value I've found so far.
KSM is online now
post #9 of 10 Old 01-15-2018, 03:36 PM
Right, Ryan Reza. Closer to you. Knowledgeable mechanic.
Adventure Motorcycle Tech
post #10 of 10 Old 01-16-2018, 07:58 PM Thread Starter
KSM
KSM's Avatar
Pulled the rear shock and shipped it off for the upgrade today. Nothing to do but wait for it to return along with the new fork springs kit.
Sigh...
KSM is online now
