Michelin anakee 3 review - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 23Likes
post #1 of 40 Old 09-12-2017, 02:17 PM Thread Starter
Hard miles's Avatar
During my ownership of the Vee I have run Tourance tires and K76's (Heideneau) (front and rear). I stayed away from Michelin tires believing that you paid for the "name" not necessarily tire quality and durability. Then in 2017 I was reviewing various tires (prices, durability and stability under load). In this particular forum they were discussing the pros and cons of the anakee 3's with one poster simply stating "just try it" and I did.
In the summer of 2017 I was preparing for a cross Canada trip from Nova scotia to British Columbia. Minimum mileage 10,000 km. I had done the trip before but had to change the rear tire (tourance) in Ottawa on the return trip. This time I decided to use a K76 (heidenau ) on the front and a Anakee 3 on the rear. Pressure 36 front and 41 rear. Weight on the bike including my self and camping gear was slightly over 400 lbs. For the purist it's ok to mix bias ply with radials. In an attempt to extend tire durability my max speed was 100km/hr even in 110 km/hr zones (4 lane roads).
I was lucky in that it was sunny for the 17 days with head winds headed west and back winds headed east. So the wind factor more or less cancelled out.
The roads were, in general, in good condition with construction zones here & there. Max speed limit in Ontario ( hwy 17) ranged from 50 km to 90 km with a lot of hills. Average temp was above 25 C with the humidex being above 30 C.
Taking off and stopping were neither fast nor slow and largely depended on the traffic around me.
On the return trip (nearing Ottawa) the tires were in excellent shape with plenty of tread so I traveled the last 1200km at 110 to 120 km/hr.
For the tires: The front K76 acted as expected with little wear. The anakee 3 after 10,000 km had plenty of tread left.
I am now at 12000 km with the tires and the Anakee 3 has 5 mm of tread left (center) .
At this point I am being aggresive with the bike in an attempt to determine why the bike refuses to accelerate past 5000 rpm in 5th gear (probably fuel pump blockage).
In conclusion I am very happy with the rear anakee 3,; good mileage & dependable. It is now my go to tire for long trips and heavy weight. I fully expect to get 15000 km on the rear tire once I fix the bike. The front K76 is also a good tire, and when the tire begins to scallop simply turn it 180.
Brian
SECoda likes this.
Hard miles is offline
post #2 of 40 Old 09-12-2017, 05:45 PM
BrianS's Avatar
If I go down to Atlanta at the end of the month I need to change my tires, this info is quite helpful. Thanks for the review.
Hard miles likes this.
Toronto, Canada
2015 V-Strom 1000
BrianS is offline
post #3 of 40 Old 09-12-2017, 07:03 PM
ToothDocJay's Avatar
I put them on my 2006 DL1000 and have put roughly 6000 km on them. They handle great and, since I live on the wet west coast (No so much this summer!) I've been very happy with how they handle rainy conditions.
The only time I've felt any slippage was when I was on the road early at the start of a rain storm after a good month or more without rain. At that point it literally looked like someone had spilled dish soap or laundry detergent everywhere because there was foam all over the roads.
ToothDocJay is offline
post #4 of 40 Old 09-22-2017, 10:38 PM
One of the best tires if not the best I ever had on my 650. Very good on dry, wet and gravel as well. Got over 22000 km out of the set. Surprisingly rear one was in better shape then the front one. Just 2 days ago I installed Michelin Road Pilot 4 on the rear. It performs superb. Let's see how long it is gone last tough.
Rick123 is online now
post #5 of 40 Old 09-27-2017, 02:51 PM
SECoda's Avatar
My tires are nearly due and the local motorcycle tire place has Michelin on sale. I think this time Anakee 3's it is.
Just made an appointment for 10 am tomorrow.
Lrobby99 likes this.
SECoda is offline
post #6 of 40 Old 09-28-2017, 10:42 AM
JackinCT's Avatar
I'm on my second set of Anakee 3's and I've been completely happy with them in all conditions.
My first set lasted around 14,000 miles (yes miles) and still had a bit of life left, though they were squared off quite a bit. The mechanic at the dealer was shocked but he knew I wasn't joking because he had installed them in the first place. He was also surprised to find two plugs in them that had worn off on the outside to the point you couldn't see them at all.
One thing I really like about them is they do very well in sand. We can drive on the beaches on the East coast of Florida and the large surface area of the tread pattern allow it to stay on top instead of digging in like most other tires I see on the sand.
2006 DL650 with almost enough farkles.
JackinCT is offline
post #7 of 40 Old 09-28-2017, 10:59 AM
SECoda's Avatar
Mine are being installed right now.
SECoda is offline
post #8 of 40 Old 09-28-2017, 04:04 PM
SECoda's Avatar
I just ran the new Anakee 3's in this afternoon about 100 miles or so and nearly had a furry encounter. Front and rear cameras are always on.
Lrobby99 and JackinCT like this.
SECoda is offline
post #9 of 40 Old 09-29-2017, 10:01 AM
SECoda's Avatar
I really like the Anakee so far after only 200 miles. They track nicely on the twisties. They do sing a bit at a lower frequency - especially the rear I think. More than the stock Bridgestone's and maybe a bit less than TKC70's. Most noticeable at about 40 mph.
SECoda is offline
post #10 of 40 Old 09-29-2017, 11:03 AM
madscrapper85's Avatar
off topic that's the biggest freaking tank bag I've ever seen you sleep in that thing or what.
kd70qc and Devilsfan30 like this.
madscrapper85 is offline
