New bike, bumps on tires? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 11 Old 09-02-2017, 03:29 PM Thread Starter
omgyouresexy's Avatar
Question New bike, bumps on tires?
Hi all, new Strom rider here. I recently purchasing a 2007 from a guy locally with a set of Anakee 2's. The rear tire seems to be in good shape with plenty of tread life. The front has less tread left (almost to wear bar), but I noticed that there are these weird bumps on some of the tread blocks and the blocks themselves are not work appropriately. See attached picture. Is this of any concern?
If/when I do replace them, I assume it's not critical to replace them with another Anakee 2. I expect I'm going to be more of a 90/10 rider, but didn't know if it was important to match a 70/30 front with a 70/30 rear. Any reason not to put a different tires from the tire thread on it?
Should I consider putting a 70/30 on anyway, just so I have slightly better off-road capability if I find myself in that situation? My only complaint about the Anakee 2 front now is that it's pretty loud, but not an issue with ear plugs.
Thanks for the advice. This is my first ADV bike, everything else was a cruiser or sport bike so on/off tire selection is a new area.
Johnson City, TN... originally from NC
Rides:
2008 V-Strom 1000
2006 Kawasaki Nomad 1600 (w/ sidecar for the boy)
omgyouresexy is online now
post #2 of 11 Old 09-02-2017, 06:03 PM
Those are worn tires and blisters like that indicate a problem.
You can choose any brand you like for the front and let her rear wear out naturally.
You might check the date stamp on the rear tire. It may be old and old tires won't give the best service.
Lots of us like Shinko for street and the odd dirt travel.
post #3 of 11 Old 09-02-2017, 06:43 PM
marcham's Avatar
Don't ride on that tire!
90/10 are ok on hard packed dirt, they suck on gravel... Ive been very happy with Shinko 705s after trying some Tourance. I'd only go back to Tourance if I never left paved roads...
Sent from my SM-T700 using Tapatalk
2015 VSTROM 650 X ABS EXP
marcham is offline
post #4 of 11 Old 09-02-2017, 07:29 PM
blaustrom's Avatar
How old are these tires? Check out that rear tire very carefully to make sure it's not dry rotted.
The front is toast and needs replaced. If you want to stay with mayor Brand Name tires look for Anakee 3 or Tourance Next. There are may other ones. Google here and find hours of reading and as many opinions as posters (almost).
I got a lot of miles out of my Tourance Next and no weird wear pattern, so that's why I replaced it with the same.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 11 Old 09-02-2017, 07:40 PM
ommoran's Avatar
I agree, I wouldn't ride on those.
I'm a big fan of the Bridgestone battlewing tires, but again good for gravel and hard pack dirt and really good on asphalt - especially riding in wet of the Pacific North We(s)t.
2011 Wee-strom and loving it.
ommoran is offline
post #6 of 11 Old 09-02-2017, 10:20 PM
Stalky Tracker's Avatar
Another Battlewing fan. Been through numerous sets, get about 15-17,000 front and 10-12,000 rear. Probably could get a few more miles, but change early to avoid changing on the road during a trip. Ok on gravel.
The Shinko's and Mitas look interesting though.
bobbyvstrom likes this.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #7 of 11 Old 09-02-2017, 10:34 PM
MrF
MrF's Avatar
I'm still on my stock tires on the Glee, so I can't offer a lot there, but I will echo the "don't ride on that" one more time. I've only ever seen bubbles on the sidewall, never on the tread, but I wouldn't ride on that on a car other than to get to a tire shop, let alone a bike. Sorry you have to do maintenance so soon on your new ride.
2016 V-Strom 650
MrF is offline
post #8 of 11 Old 09-03-2017, 07:25 PM Thread Starter
Thanks for the heads up everyone! I actually didn't even notice the bumps until taking the pictures for this thread. The back doesn't have any dry rotting or anything that I can see, but I'll be down there soon to do the spacer mod and will get a good check on it and the bearings.
Rides:
2008 V-Strom 1000
post #9 of 11 Old 09-03-2017, 08:48 PM
gspy4u's Avatar
As others have said, DO NOT ride on those things. I would be changing them for anything before trusting them
gspy4u is offline
post #10 of 11 Old 09-04-2017, 12:06 AM
blaustrom's Avatar
Check the age of that rear tire.
Blau2 2014 DL1000A
