Preload on VSTROM 1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-27-2017, 10:35 AM Thread Starter
dxaxrxc's Avatar
the manual says that it comes set a 3 bars in the front and 2 lines on the rear shock. Does anyone know what weight rider that is set up for? I don't have any help at my house to do the zip-tie trick. i have a wife and 3 daughters who are not interested. LOL. I just want to be in the center of the travel for the springs and shock and i figured they had to have a number in mind (average size/weight rider) when they came up with the standard settings. I weigh 173 btw which i think is average so i left it at the standard settings. Anyone know?
dxaxrxc is offline
post #2 of 11 Old 07-27-2017, 12:28 PM
hunt1moore's Avatar
Personally, I feel like the stock springs are for 98 lb Japanese guys. I would pre-load them a lot and raise the forks in the clamps about 10mm.
The rear doesn't have a pre-load adjustment (quoting GW) However it has a ride height adjustment.
I would be looking at Sonic Springs for a new set of fork springs.
PC-V, TRE, CR8EIX , ECM, K&N, RDL, PR4, PC-8, EB H4, WERKS, Madstad 22", 17/43 gearing, AdventureTech: Fork brace, shelf, mirror extenders, SpeedoDRD, wheel spacer, Head's-Up voltage monitor, Goldwing pegs, Sonic 1.1, Wolo Bad Boy, ExTuff Helmet Hook.
hunt1moore is offline
post #3 of 11 Old 07-27-2017, 12:51 PM
?? Very early Vees don't have a front preload adjustment. A red one will be a 2006 model which should have 5 lines on the front and five lines on the rear to indicate preload level. All years have rear preload adjustment. The preload adjustment is the ride height adjustment.
You don't need help to do a decent job with the zip tie trick in front. Tie the zip tie on the fork tube at the dust seal. Then get get on and and change from one leg supporting the bike to the other leg as you kick the bike from one side to the other making sure to have both feet off the ground in the transition. Then pull the bike up on the side stand to get the weight off the front and measure the distance between the zip tie and the dust seal. You want about 40 mm. The range is 25-33 percent of the full travel, not half. You need more compression room than rebound room.
You can try three lines on the rear and see if you get any bottoming. If you do, you add more preload.
post #4 of 11 Old 07-27-2017, 01:36 PM
2006 was maroon. I think 2012 was the only year for red on the DL1000.
2014 DL1000 - Sold
2010 Triumph Scrambler- Sold
2014 KLR650 - Sold
2017 Honda CRF250L - current
2016 Honda VFR1200X - current
Slow Eddie is offline
post #5 of 11 Old 07-27-2017, 02:08 PM
Got it. My resource for colors did not go that late.
Wait. The 2006 color is listed as candy Sonoma red.
The 2012 is brighter Suzuki Pearl Mira Red though. http://www.colorrite.com/wizardresults.cfm
post #6 of 11 Old 07-27-2017, 02:19 PM
Lrobby99's Avatar
2006 DL1000 maroon?
2006 DL 1000....red
Lrobby99 is offline
post #7 of 11 Old 07-27-2017, 04:17 PM
hunt1moore's Avatar
"Changing the preload does not stiffen the spring. The spring stiffness is inherent. Cranking the preload clockwise raises the rear and counterclockwise lowers it. It's called setting the sag for the load. See The Science and Black Magic of Suspension Setup"
I mis-understood
post #8 of 11 Old 07-27-2017, 04:57 PM
Right. Changing the preload changes the sag, or ride height. If maximizing the preload doesn't get the ~40mm you need, a stronger spring will be needed.
post #9 of 11 Old 07-28-2017, 09:32 AM Thread Starter
dxaxrxc's Avatar
super helpful fellas. I have looked at the Science and Black Magic of Suspension Setup before. But this just makes more sense to me. I appreciate it.
1982 Suzuki GS450 (Black) "bobber" sold with 24k
2007 Suzuki SV650 (Blue) traded in with 33k (got with 5k)
2012 Suzuki DL1000 (Red) current bike bought last year with 2500 miles currently at 14k
dxaxrxc is offline
post #10 of 11 Old 08-22-2017, 09:11 PM
Rmplstlskn's Avatar
As a 320 pound rider, my pre-loads are maxed out. I am looking into new shock for rear and new spring for front, or maybe new spring for rear too, but from what I have read, the rear shock is so/so performer, if even that. But on a 2011, I don't want to dump lots of money into it, so time will tell how the max settings work for me.
Rmpl
2011 V-Strom DL650A Black w/ABS
Rmplstlskn is offline
