Put on some Shinko 705's - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 13 Old 07-17-2017, 02:10 PM Thread Starter
Motosapien's Avatar
Ran them at 38/36 on the gravel and I found them amazingly sure footed. I was riding alot faster with them than the stockers. 40/38 on the blacktop. As others have noted, they are eager to lean into turns. I think the aggressive tread has more friction than the stockers and it slows the front wheel causing it to lay over. Pretty much used to it after a couple rides. Have yet to corner them hard but I did cruise up to about 105 indicated and the were smooth at speed. You can feel the blocks rumble a bit below 30 or so.
Big B, Lrobby99, RCinNC and 1 others like this.
75 DT 400 / 81 900FSS / 02 DL1000 / 02 SV650 /14 DL1000A
Motosapien is offline
post #2 of 13 Old 07-17-2017, 03:02 PM
Lrobby99's Avatar
The blocks rumble and sing!
Talented tires, if you ask me.
Big B and Motosapien like this.
Lrobby99 is offline
post #3 of 13 Old 07-17-2017, 03:07 PM
Wait until you try the 805/804 combo. Same rubber compound with amazing blacktop performance, and way better off road. Plus they look great.
2stroke is offline
post #4 of 13 Old 07-17-2017, 04:13 PM Thread Starter
Motosapien's Avatar
I'm heading out West in a bit so I will see how I like them on road. Probably put 4,000 miles or so. If I didn't enjoy the scenery and solitude of the forest gravel roads I would have stuck with the Trail Wings.
post #5 of 13 Old 07-17-2017, 05:09 PM
Bikeless 4 now
Outbackwack's Avatar
My 804 rubbed the fender on my Glee in dirt so now I have my TKC70 on. But the Shinko's are good tires for the money! Have fun and be safe!
Outbackwack
Get busy living, or get busy dying...
http://www.visitedstatesmap.com/image/AZCOCTILINIAKSKYMEMAMOMTNVNHNJNMNYOHPASDTXVTVAWVWY  sm.jpg
Outbackwack is offline
post #6 of 13 Old 07-17-2017, 05:12 PM
Yeah, mine did too. Just slotted fender, and raised it about 1/4". Took care of it.
2stroke is offline
post #7 of 13 Old 07-17-2017, 11:11 PM
Your math is interesting. A bit off but interesting. I run 705's and find them quite adequate.
Oh, it's air pressure not road/dirt values. I just fall down so I don't worry about AP.
post #8 of 13 Old 08-13-2017, 11:32 AM Thread Starter
Motosapien's Avatar
Have about 2K miles on the 705's so far. No abnormal wear noted, just a hint of squaring off on the rear. They are much more compliant on bumps than the stockers. 40 psi rear and 38 front seems good for pavement and gravel.
post #9 of 13 Old 08-13-2017, 12:02 PM
RCinNC's Avatar
I think my last three or four tire changes have been 705's. However, when this current one wears out, I may just try an 805 on the rear, and see how they ride.
RCinNC is online now
post #10 of 13 Old 08-22-2017, 09:06 PM
Rmplstlskn's Avatar
Just put 705's on my DL650A and like the tread pattern for non-pavement and they seem to corner nicely and confidently. For the price, I am way happy!
Rmpl
2011 V-Strom DL650A Black w/ABS
Rmplstlskn is offline
