Avon TrailRiders or Pirelli Scorpion Trail II - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 29 Old 05-06-2017, 08:07 PM Thread Starter
Looking for street tires that provide excellent handling and braking while complementing the look of the DL650, hence considering these 2. No plans for anything off road with possible exception of short stints on dry hardpack. Both are of recent developement, thus use the latest tire technology and design. Reading reports that describe somewhat shorter life span for the Avon rear tire compared to comparable street tires, possibly due to softer rubber in center of rear tire.
While neither is a bad choice, wonder if folks have experience with both and appreciate a comparison. Is one superior to the other in function or durablility?
Thanks in advance,
Mark
mpom is offline
post #2 of 29 Old 05-06-2017, 08:27 PM
Looking to replace my Heidenau K60 scouts with these, can't complain about the wear rate but after a couple of little slippy incidents and a now inherent distrust of these tyres I've been looking at the Trail riders.
My ABS seems to activate far earlier than I would expect as well.
Have you seen this review ?Earth-Roamers : Avon TrailRider review after 25,000 km
I doubt wear will be a problem for you if it wasn't for these guys.
SECoda likes this.
gunnabuild1 is offline
post #3 of 29 Old 05-07-2017, 06:18 AM
I purchased avon trailrider in February for this season but i didn't mounted them yet. My understanding of the review is that they will last long if you ride gently, but might melt if pushed hard.
Envoyé de mon LG-K210 en utilisant Tapatalk
SECoda likes this.
03 DL1000
PCIII USB
Givi E52/E360 cases
Sargeant seat
Enduro Guardian skidplate
Givi crashbar
Adventure Tech fork brace
Progressive suspension fork spring
Racetech Gold Valve G2R
Elka rear shock
Madstad Robobracket windshield
Flat4awd is offline
post #4 of 29 Old 05-07-2017, 07:07 AM
spike55_bmw's Avatar
I like the Avon AV54 r / AV53 f. The front is still in really good shape at 6500 miles but the back isn't.
I have 1 millimeter (1/32") or a fraction more down the middle. I keep the rear at 40-41 psi. Right now, the rear is close to not passing Pennsylvania's annual vehicle safety inspection (requires 2/32" tread depth down the middle) depending on which garage I would use.
The rear could probably remain street legal up to 10,000 miles if 50% of the time was spent riding on gravel / dirt at less than 40 mph like the Earth Roamers.
Sept 2016, I ran some interstate at 70-80-90 mph up in Vermont / New Hampshire / Maine and when I would stop, I could smell burning rubber and the tire was hot but at approx 45 psi when I would check. It was just me and about 30 lbs of gear. I did run some dirt like the whole Bayley-Hazen almost to Canadian border and the tires did OK.
Great tire but not as hard down the middle as I would have liked (you can see center band of rubber versus the edge).
spike55_bmw is offline
post #5 of 29 Old 05-07-2017, 01:31 PM Thread Starter
This is the wear concern I have, mentioned by other folks on other forums as well.
Wondering if the wear characteristics of the Scorpion Trail II are similar, but have not found a head to head comparison.
Both seem excellent 90/10 tires, trying to find out if one is superior, or if they are very close in performance and wear, in which case the choice becomes more difficult.
Would not be surprised if wear is comparable, as I suspect there is no free lunch; good handling and grippiness comes with the price of shorter lifespan.
Thanks for the feedback!
Mark
mpom is offline
post #6 of 29 Old 05-07-2017, 04:55 PM
Already have these Avon TrekRider AV84(f) / AV85(r) sitting in garage ready to go. I don't think that these are multi-compound, just deep tread down the middle.
post #7 of 29 Old 05-24-2017, 07:15 AM
Made the switch at 6868 miles from Avon TrailRider to Avon TrekRider only on rear. Also went to a 48-tooth sprocket to add a little low end. "Seasoned" the new rear tire yesterday with 100-miler to slowly narrow the "chicken strips". No dirt yet.
NVDucati likes this.
post #8 of 29 Old 05-24-2017, 10:31 AM
NVDucati's Avatar
I have never ridden on the Scorpion Trail II so I can't speak to those tires. I do have a set of the TrailRiders on my V2. I ride them at 35lbs cold both F&R. I ride solo , mainly back roads and rarely gently.
Currently they have about 4500 miles and look fine. I expect, like all my tires, they will last to that 6800 mark that Spike cited.
They warm up fast, by design. We got rained on pretty hard a couple of weeks back just as it got dark. Because there had been no rain for a while I turned the traction control to max but never flickered the TC light. I don't exclusively use Avon tires but have been using them back to '74 (Avon Venoms). They are always a viable choice and I find that they stay round right to the end. The TrailRiders were 3 years in development and at first I was sad to see the Distanza line ended. (bought one last pair for my SV650) But these are just fine and a bit better on the road insomuch that they are now 90/10 and they wrap around the edge a little further. I prefer the 90/10 over sport/trackday tires because around here the roads are never swept between heats. We have those mini, mini land slides which leave gravel between the car tracks for days and lot's of road-snakes.
Last, I have seen the occasional mention of melting. They won't melt. But after a vigorous session if you get down and closely sniff them (no photos please) you can smell the rubber. Gota love the smell of hot rubber.
Member: AMA
NVDucati is offline
post #9 of 29 Old 05-24-2017, 10:55 AM
SECoda's Avatar
I am following two local guys with the Trail Riders to see how long they go and the longest just broke 11,000 miles on his rear tire. He rides mainly pavement at varying speeds and shorter trips like I do. The second guy just broke 9000 miles on the rear and has plenty of mileage left.
I would be curious as to what you guys get with K60s. My buddy switched from K60s to the Trail Riders after about 12,000 miles on the K60s. It appears he will pass that on the Trail Riders or at least match it.
What we hear is the heat from very fast long highway rides will kill them (or most tires). We just don't do much of that here. There are huge disparities being reported on the Trail Riders based on riding habits and temperature it seems.
SECoda is offline
post #10 of 29 Old 05-24-2017, 03:58 PM
On my 3300 mile trip, I ran the TrailRider rear at 40-41 psi (cold) since I was carrying sidecases with +/- 35# of gear plus a drybag on the tail rack. I also had a tank bag and then drybags of tools on the "ears" of the crash bar. Altogether, including me, it had to be close to like riding with two-up and they recommend 41 psi on the rear. Around town I carry the tankbag and my rainsuit is on the tail rack.
I liked the Avon TrailRider tire as long as it lasted (some off-road but rather be on the KLR with Shinko 700 / 244 tires) but I often smelled burning rubber after any sort of continuous long distances.
You can see how the base layer of rubber (dark shapes down the middle) start to come through. The cords would have been next.
I had to run the bike through PA state vehicle safety inspection and the tire wouldn't have passed +1/32" tread depth (confirmed when new tire was installed by same garage I went back to the following day and successfully completed the inspection).
10000 miles could be possible with a lighter rider than me, less gear than I tend to carry, shorter runs resulting in less heat, and more dirt (~30 mph) than what I did.
