Where to get help with suspension set-up? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 12 Old 05-03-2017, 10:59 PM Thread Starter
bajakirch's Avatar
I've been listening to some older episodes of the Adventure Rider Radio motorcycle podcast; specifically, a 2-episode series they did on nothing but suspension. I came away from it with the understanding that I'm a complete dolt for ever rider more than a mile on stock suspension (and, at 50k+ miles, my old Kawasaki Concours was probably a little overdue for a suspension upgrade).
After listening to a combined 3+ hours of talk about suspension, I also understand that I'm never going to be a suspension expert -- sag, rebound damping, compression damping, spring rate...it's all greek to me.
So, while my 2012, at around 20K miles probably still has some life left in the stock set-up, I'm already thinking about swapping things out down the line.
What I'm wondering is how I can find someone locally that could help me get the bike set up properly. From what I understand, this isn't the sort of thing you want to rely on your average dealer mechanic to advise you on -- you need someone that really knows this stuff.
Also, I know suspension parts come in all budget ranges. But can anyone ballpark what I should be thinking about setting aside for suspension upgrades to the front and rear? I bike on a budget, so this isn't the sort of thing I can drop $2k on -- I may only be able to afford new springs/fork oil up front and perhaps a new, rebuildable shock for the rear.
Finally, while I'm an intermediate wrencher, this seems like the sort of thing I'd want someone else to do the install with. How much extra does it add to have someone do the work?
bajakirch is offline
post #2 of 12 Old 05-04-2017, 10:20 AM
You want someone locally? Try googling racing shops and suspension shops.
I know that Sasquatch in Idaho can get your stock shock in good shape for a bargain price($300?) compared to most aftermarket shocks. Emulators seem to be a good thing for the front forks.
The specifics of exactly how to get it right for you is as you said it's all Greek
Figure 100 dollars an hour minimum to cover shop costs. Sasquatch and I changed out the shock in a dirt parking lot in about 20 minutes. Woulda been quicker if we were on a good cement pad.
Changing fork springs is simple, pull the cap, remove old and install new replace caps. Otherwise a few hours in the shop to pull the forks and do the renew.
That would be plus sundry parts like new seals and such since they are in there anyway.
2mstone likes this.
post #3 of 12 Old 05-04-2017, 10:20 AM
The forks are the inexpensive part. It will run you about $250 for springs and a pair of emulators. The shock starts at $300 for a rebuild of your stock shock, and goes up to $1000 for an Ohlins.
gplassm is offline
post #4 of 12 Old 05-04-2017, 09:21 PM Thread Starter
bajakirch's Avatar
It's interesting to hear several of you talking about rebuilding the stock shock. On the shows I listened to, they interviewed probably 5-6 MC suspension experts. They didn't agree on everything, but the one common thread was they all said stock shocks were, with very few exceptions (high-end KTM motorcross bikes, for example), non-rebuildable and should be considered wear items to be replaced at 25,000-30,000 miles.
post #5 of 12 Old 05-04-2017, 09:37 PM
A few places have the knowledge and tools rework the stock shock so it is rebuildable.
post #6 of 12 Old 05-04-2017, 09:47 PM
Mine had 3 times that much when it became a pogo stick. Sasquatch put in a gas cartridge and gave me a spring proper for my weight and load.
The big companies always say they are mo bettah.
What you don't know is to their benefit.
post #7 of 12 Old 05-04-2017, 11:55 PM
Sag...how much the suspension settles from wheel-in-the-air to fully dressed rider aboard (or rider & passenger). We want about 40 mm, front & rear, on the strom.
Preload...the adjuster of the spring mount to get the correct sag. It does not stiffen nor soften the suspension.
Rebound damping...how fast the damper extends.
Compression damping...how fast the damper compresses.
Step 1...get the correct springs for your loaded riding weight. Sonic Springs
Step 2...set the sag.
Step 3...Which bike do you have. It isn't listed in your profile, nor you location. For the 650s, improved damping valves are a big help. I'd go with the newest, the Cogent Dynamics Drop In Damper Cartridge. http://www.motocd.com/product/ddc-complete-package/
For a 2002-2013 1000, the RaceTech Gold Cartridge. For a 2015+ 1000A, ditto. Nothing available for the 2014 1000A.
Step 4...shock. Whoever either reworks the stock or sells you a new one, be sure they know what damping you like. Do you want desert racer stiff or smooth pavement plush? They need to know.
Rides2Work likes this.
post #8 of 12 Old 05-05-2017, 12:59 PM Thread Starter
bajakirch's Avatar
Thanks -- good point on the bike owned. I never updated that once I bought my 2012 Wee.
As for riding style, I've been a 99% street rider...though, since my state hasn't seen fit to invest in much infrastructure improvement, my morning highway commute is rapidly turning to washboard conditions.
With the Strom, I'm a little more confident on the gravel roads, but still wouldn't expect to do much of anything beyond rough gravel or an occasional forest road in the foreseeable future.
post #9 of 12 Old 05-05-2017, 02:13 PM
My advice is to fiddle with your front fork sag and rear shock sag adjustments to learn how to do that. If you are over 150 lbs, you probably won't be able to get them exactly where they need to be "by the book" as the spring rates won't be high enough.
Springs and different oil in the front forks are a start. Cartridge emulators are not really cheap so forget about those right now.
Have your rear shock modified by Sasquatch or Daugherty Motosports. Both can and do upgrade both the valve action and can install a proper spring on your stock shock. Here is a price list from Daugherty: Stock Shock
For a street rider, even an experienced rider, these are going to be hard to beat.
Suspension upgrades can transform the bike. Make it so much easier to ride with confidence. You go faster while thinking you are going slower!
realshelby is offline
post #10 of 12 Old 05-05-2017, 03:52 PM
I just pulled forks and shock out last night and heading over to the Sasquatch to drop them off. I've only heard good things about his work.
I expect to be going for the full meal deal of modified shock, springs, and revalve.
Adventure Power Sports, LLC
notacop likes this.
2014 DL1000 Khaki
IDRIDR is offline
