angled tire valves added to stems - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 26 Old 04-15-2017, 10:06 AM Thread Starter
robfilms's Avatar
is there a recommended angled tire valve which i can screw onto my tire's stems so when i fill up with air, i can easily access the air hose's nozzle?
thanks in advance.
be well.
rob
2013 Yamaha FJR1300 - Stone Grey
2009 Suzuki DL650 Wee-Strom - Le Grande Orange
2006 Kawasaki Z750S black
1974 Yamaha RD350 maroon with a white racing stripe!
robfilms is offline
post #2 of 26 Old 04-15-2017, 11:37 AM
PineLaneRider's Avatar
I want to see the discussion on this. Things I've read say it's a bad idea, additional stress. I've thought about carrying one with me and screw it on when needed then take it off to ride.:lurk5:
PineLaneRider is offline
post #3 of 26 Old 04-15-2017, 11:37 AM
blaustrom's Avatar
Maybe not the answer you are looking for. For the same reason I installed a angled metal stem. It never wanted to stay put and always wanted to turn, no matter how much I tightened it. And in the second season it started to leak to the point that I had to remove it to be able to go on my trip. I have not found a good solution other than using a pressure gauge with flexible hose connection. If the pressure is low I can attach the compressor nozzle to the gauge. That works fairly well.
billteugene likes this.
blaustrom is offline
post #4 of 26 Old 04-15-2017, 12:40 PM
nvr2old's Avatar
Had my angled metal stems in for more than 100K and 10 years. Had a rubber one tear out at high speed years ago. A quality stem, properly installed, should not leak. I feel much safer with the metal.
Example-
https://store.soundrider.com/collect...re-valve-stems
2thDr, Vhawg and billteugene like this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #5 of 26 Old 04-15-2017, 12:42 PM
billteugene's Avatar
Great question; I hate the lack of clearance around the valve stem.
billteugene is offline
post #6 of 26 Old 04-15-2017, 01:01 PM
If you install the proper sized rubber valve stems, and some recommend doing that with each tire change, there is very little chance of any failure. Short of getting into mud and ripping them loose. Metal ones with nuts to tighten them to seal, either straight or angled, have a history of being somewhat more prone to failure. There is a reason you don't see them as OEM equipment. The angled ones, while convenient, invite all sorts of problems. They are in a constant strain at high speeds from centrifugal force. Even washing the bike means you should be careful not to move them.
My solution is one of the gauges that have the fitting that clamps onto your valve. These Viair units let you clamp onto the valve, check pressure, add, and adjust with the bleed button. These type of valve fitting seal quickly and easily.
realshelby is offline
post #7 of 26 Old 04-15-2017, 01:06 PM
Example-
+ 1 Great Product have them on my BMW and Wee same as above over 100k and no problems
Norm
Riding for 60 years
Current Rides
2018 Suzuki DL 1000 ADV.
2010 Yamaha XT250
2005 BMW R 1200 RT Gone
2011 Suzuki DL650 Gone
Plus 43 other Dirt and Street Bikes from AJS to Harley in my past...
Old Codger is offline
post #8 of 26 Old 04-15-2017, 02:20 PM Thread Starter
robfilms's Avatar
all-
i might be leaning towards PineLaneRider's suggestion of carrying an angled tire valve and use it when needed.
for me, the rear wheel air valve on my 2009 wee with black cast wheels is always hard to access.
the front is a small amount easier.
realshelby's thought is a bit overkill for my more modest needs.
i do have a flexible hose air gauge with a bleed button release.
now if i could only get the air into the tire as easily as i can check it, well that would be great ;-)
i look forward to any other suggestions.
be well.
rob
robfilms is offline
post #9 of 26 Old 04-15-2017, 02:35 PM
nvr2old's Avatar
Semi tractors and trailers all run metal stems without problems.
I know a couple that had a near new Goldwing that the rubber stem broke and put both of them in the hospital.
Like Realshelby says, if you run them, change them out with each tire change. Also buy the shortest one possible. There are some that only stick above the rim about 1".
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
nvr2old is offline
post #10 of 26 Old 04-15-2017, 03:25 PM
blaustrom's Avatar
Originally Posted by robfilms View Post
all-
be well.
rob
Check my post. I added a link to the kind of gauge you are looking for. Quality product, reasonably priced. Plus you can check bicycle tires as well.
