Dyna beads - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 33 Old 03-30-2017, 07:04 PM Thread Starter
Dyna beads
Has anyone used dyna beads or couteract beads to balance tires?
rallysquirrel likes this.
ride on is offline
post #2 of 33 Old 03-30-2017, 07:56 PM
gsinpei's Avatar
This is a lot cheaper and seems to work fine, just use the same weight as you would with official beads.
https://www.walmart.com/ip/Crosman-A...00-Ct./9222912
Supatramp likes this.
2005 DL-650
gsinpei is offline
post #3 of 33 Old 03-30-2017, 08:21 PM
RCinNC's Avatar
RCinNC is online now
post #4 of 33 Old 03-30-2017, 09:43 PM
Hank122's Avatar
I've been using the Counteract tire balancing beads, they've worked well for several tires changes done on 2 DL650s.
The trick is to getting the hang of pushing them through the valve stem with the plastic tube they provide, you have to be patient and do a bit at a time.
You can buy just the replacement beads but they're not exactly the best bargain out there. I've found that I can re-use the beads when swapping a tire if I'm careful to dump them into a bucket when I take off the worn tire.
Henry
"Rock bottom will teach you lessons that mountain tops never will..."
2016 V-Strom DL650 (red) 'Sweetness'
2011 V-Strom DL650 (white)
Hank122 is offline
post #5 of 33 Old 03-31-2017, 01:02 AM
My oh my.....did you utilize the wonderful Google search box function?
DL1000 Pilot likes this.
post #6 of 33 Old 03-31-2017, 01:13 AM
RCinNC's Avatar
Ding Ding, we have a winner!
notacop likes this.
post #7 of 33 Old 03-31-2017, 07:09 AM
PerazziMx14's Avatar
I have put "balance beads" in over a 150 tires I changed for friends and family and only have one complaint. YMMV.
PerazziMx14 is online now
post #8 of 33 Old 03-31-2017, 08:07 AM
madscrapper85's Avatar
Use them in the last three sets of tires I've changed and they have been awesome, don't see me going back to wheel weights anytime soon.
madscrapper85 is online now
post #9 of 33 Old 03-31-2017, 09:32 AM
Will those fit through a valve stem? It seems that they would be too big. How would you get them into the tire?
gplassm is offline
post #10 of 33 Old 03-31-2017, 10:06 AM
Rick505's Avatar
I've used some sort of balance beads for the last three or so tire set changes. Initially I used the real Dyna Beads brand and had no issues. Attempting to save $$$ I ordered some replacement from an eBay seller (in Arizona I think) that sells them by the ounce. I tend to install them between setting the first and second tire bead. I have been able to get them installed through the tire valve stem, with the core removed of course, but was a real pain and took quite a bit of time. I've had no balance issues using them although I tend to agree the "science" is a bit voodoo to me.
Rick
Rick505 is offline
