Dropping new fork springs from the top - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 11 Old 03-10-2017, 05:54 PM Thread Starter
Can you drop new springs from the top and not having to worry about dismantling the forks from the bike?
My bike has fresh seals and oil from the PO and I just want to upgrade the springs.
2005 Wee
jfman is offline
post #2 of 11 Old 03-10-2017, 06:35 PM
Tim P.'s Avatar
Yes, and likely top up the fork oil accordingly
Sent from my SM-G920T using Tapatalk
Tim P.
05 Blue DL650
82 Magna V45
84 Sabre V65
Tim P. is offline
post #3 of 11 Old 03-10-2017, 07:20 PM
cyclopathic's Avatar
You would need to move handlebars out of the way and prop front. Do you have a center stand?
cyclopathic is offline
post #4 of 11 Old 03-10-2017, 08:11 PM
kiwi_outdoors's Avatar
yup - done it
2005 Wee
I "tied" (bolted) my rear wheel down to the floor - bike was on centerstand
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #5 of 11 Old 03-11-2017, 12:17 AM
RichDesmond's Avatar
2005 Wee
That will work in this case. I'd double check the oil level.
Rich Desmond
RichDesmond is offline
post #6 of 11 Old 03-11-2017, 10:24 AM
KevinP65's Avatar
The fork oil is supposed to be measured with the tubes vertical (plumb)and there is a rake angle (?) on the bike and fully compressed if I remember correctly. Not sure how easy that would be to do with the tubes still in the tree. Could be wrong. I have done it on other bikes with the wheel still on but still dropped the tubes. Personally, if I was replacing the springs I would drain out the old oil and flush and put in the weight oil I wanted to go with the new springs. Even if I knew the old owner did it right w/o any doubt I would probably do it all anyway with spring change-just part of the deal and just me--I never would dream of re-using valve cover gaskets if I could get new ones,either, but lots of folks do and have no problems.
wingstrom likes this.
2011 dl650
KevinP65 is offline
post #7 of 11 Old 03-11-2017, 11:13 AM
Lay down some plastic, will be a bit messy
on2wheels52 is offline
post #8 of 11 Old 03-11-2017, 11:26 AM
You "could" take out the springs and compress the forks by jacking up the wheel till it tops out.Center stand or bike lift needed. Then use a tape to measure the high and low side of the fluid and divide by 2. Not precise but will get you in the ball park. Then lower forks/wheel and add springs. May be easier with the wheel off too. Like you, though, I would probably just take the forks off. Alot less messy! Good time to check other things, wheel bearings come to mind. Head bearings too!
SpudBob is offline
post #9 of 11 Old 03-31-2017, 04:16 PM Thread Starter
Backed off the preloads, loosened top clamp pinch nuts, Pulled on one fork cap - very little resistance, pulled spacer and spring out, cut new spacer, reinstalled new spring washers and new spacer, added 50ml of fork oil to compensate for lost oil, put the cap back on, reset preload. repeat on other side.
All is well.
jfman is offline
post #10 of 11 Old 03-31-2017, 10:36 PM
Did you really loose 50ML when pulling the old springs?
Seems I measured the free space at the top using a straightened clothes hanger and coated it with chalk.
Some such value with the forks fully extended on the center stand.
I would think the fork oil loss would really be minimal when pulling out the old forks and letting the drip for a bit.
I used the Black Lab tutorial.
