Do I need the rear shock link to upgrade 650 to 1000 shock - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 16 Old 01-13-2017, 02:02 PM Thread Starter
I searched and couldn't find if it was a direct swap, or if I need the link from DL1000 to make the shock fit.
This piece.
08 650
HanzoSteel is offline
post #2 of 16 Old 01-13-2017, 04:29 PM
It's a direct swap. Vees and Wees use the same link. The Vee shock is a little longer so your seat height will be a little taller.
Lrobby99 and HanzoSteel like this.
post #3 of 16 Old 01-13-2017, 04:36 PM
Lrobby99's Avatar
is that one shot? the rod to the right looks pretty chewed up. Just wondering.
Lrobby99 is offline
post #4 of 16 Old 01-13-2017, 05:24 PM Thread Starter
That's just a picture I got off the web to show what was referring to.
08 650
post #5 of 16 Old 01-13-2017, 05:25 PM Thread Starter
Thank's for the quick reply.
08 650
post #6 of 16 Old 01-13-2017, 06:34 PM
The ugly example is how mine looks after 90K miles. I need rework the bearings.
I wonder how much better the rebuilt shock will feel with new bearings in the link?
HanzoSteel likes this.
post #7 of 16 Old 01-13-2017, 07:11 PM Thread Starter
Good point, better replacing them while I have it in pieces.
08 650
post #8 of 16 Old 01-16-2017, 09:16 PM
dmfdmf's Avatar
You might be more talented than me but when I refurb'd my rear suspension I got new bearings and tried to pull the old bearings from the cushion (Japanese for "shock") lever and made a mess. I had a bearing puller (hammer type) and it ripped out the needle bearings but left the outer race stuck in the cushion lever. The race is very thin and hard to get out without the lip that holds in the needle bearings. I called some mechanics and they were reluctant to try after I botched the job and (probably over) quoted high estimates to get me out of the jam. I found a low-mileage part-out on craigslist and just replaced the whole cushion lever, bearings and all. Soooo... after that long saga, my advice is that if you don't have a bearing press take it to a mechanic who does.
Next Up: ?
dmfdmf is offline
post #9 of 16 Old 01-17-2017, 10:10 AM Thread Starter
Thanks for pointing that out. I will inspect it and if I think it needs replacing then I will shop it out.
08 650
post #10 of 16 Old 01-17-2017, 11:01 AM
I made a goof rebuilding the forks and put the upper bushing in too soon. I used a torch to heat up the lower fork leg and tapped it on the vice and it fell out.
So the good ol' heat wrench can be a friend when pressing bearings or bushings.
As rusty and nasty looking as mine are a good cooking couldn't hurt as a starter. Just to kill the cooties at least.
