What's the difference in height and width: 130/80 or 130/90 R17 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 11 Old 10-25-2016, 10:06 PM Thread Starter
Slickrock's Avatar
I'm a knuckle head when it comes to understanding tire size. Can anyone tell me the difference in inches for height and width between a 130/80-17 and 130/90-17 tires? Stock rear size for my 83 Honda XL600r is 130/80-17. I currently have a 130/90-17 on the rear (super knobby tire). I believe the 130/90 is taller but not sure of width? I'm going to put a street tire on it for the off season so I can ride it when not on the Vee. It is super light and a rocket compared to the DL650a up to about 65-70 mph.
I can buy the same tire in both sizes but the 130/90 is cheaper by about $35. Wider and taller is better but want width over height if I compromise.
What is the 130/80-17 height and width in inches?
What is the 130/90-17 height and width in inches
Thanks, Slickrock
Slickrock (Dan)
2013 Dl650A and 1983 Honda XL600r Thumper. Lower end of Central Valley, CA.
Slickrock is offline
post #2 of 11 Old 10-25-2016, 10:15 PM
RichDesmond's Avatar
Thanks, Slickrock
There is no one answer to your question. Those are nominal sizes, not actual. Actual height/width varies from brand to brand, and model to model.
And wider isn't necessarily better, in fact it's often worse.
Rich Desmond
RichDesmond is online now
post #3 of 11 Old 10-25-2016, 10:46 PM
I'd go with what the manufacturer suggests. They have OEM values for a reason.
post #4 of 11 Old 10-25-2016, 10:49 PM
The numbers mean 130mm wide and a height of 80% then 90% of the width, both for 17" wheels. As Rich says, the actual sizes will vary. Figure the /90 tire will be a little taller than the /80 tire if they are the same brand especially.
bobbyvstrom likes this.
post #5 of 11 Old 10-26-2016, 09:36 AM Thread Starter
Slickrock's Avatar
Thanks all for the responses. I'll weigh the responses. A little taller doesn't sound like I'd notice the difference. I'm buying from Biker Bandit via Amazon so probably go back to stock tire size.
Slickrock (Dan)
post #6 of 11 Old 10-26-2016, 12:14 PM
I'll just note that there really isn't much clearance under the front fender even with a stock size knobby tire, so I am not sure a taller tire than stock is going to fit without modification to the location of the fender.
Big B likes this.
'12 DL650 ADV
'07 Victory Hammer
'06 Suzuki M50 (Traded)
MariusD is offline
post #7 of 11 Old 10-26-2016, 12:17 PM
A little taller can be a big issue with the 12 and up 650, the front fender clearance is already pushing it.
post #8 of 11 Old 10-26-2016, 03:09 PM Thread Starter
Slickrock's Avatar
As mentioned, we are talking about an 83 Honda XL600r not a DL650a. The 130/90 17 knobby tire is on there now and there is about 1/8-1/4" clearance between the tire and the swing arm.
Slickrock (Dan)
post #9 of 11 Old 10-26-2016, 03:14 PM
OOPS......I missed that, sorry about that.
Slickrock likes this.
post #10 of 11 Old 10-26-2016, 07:12 PM
fortp's Avatar
Thanks, Slickrock
130/80-17: 130mm width, and 104mm height (5.1" and 4.1")
130/90-17: 130mm width, 117mm height. (5.1" and 4.6")
So theoretically the 90 should be 1/2 inch taller.
fortp is offline
