Quick Question regarding preload adjusters - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 09-16-2016, 04:12 PM Thread Starter
strom lurker's Avatar
I bought some used 2002 forks to replace the forks that I bent around a buick in May. Seems they don't have preload adjusters. Wish I had realized that before I purchased but oh well. My question:
I still have my old forks. Is there any way to swap out the top portion of the 02 forks with the old 03 ones? If so, is it pretty much an easy swap. Thanks for any pic.
Picture is for reference.
Current Stable:
1971 Honda CB500 Cafe Racer
1974 Honda CB550
1975 Honda CB750
1981 Honda Goldwing
1993 Yamaha GTS-1000 x3
2000 Hayabusa
2003 V-strom
strom lurker is offline
post #2 of 6 Old 09-22-2016, 06:14 PM
bwringer's Avatar
Try it and find out.
I'm pretty sure the answer is "yes", but that's based mostly on very vague memories of seeing this come up before and the knowledge that Suzuki is highly unlikely to cut different threads in a fork with the same diameter.
You may need to change the length of the spacer to end up with the correct range of preload.
If you're not already familiar with the innards of these forks, you may need to peruse a shop manual for a while. There's a damper rod to deal with and you may want to get your mitts on the special tool for retrieving the damper rod first.
bwringer is offline
post #3 of 6 Old 09-22-2016, 07:07 PM
2002 means a Vee. Vee's have cartridge forks, not damper rod forks.
post #4 of 6 Old 09-28-2016, 08:36 PM
bwringer's Avatar
Yes, I know -- I have a 2002.
I was talking about the "damping rod" sticking up from the cartridge and screwed into the fork cap or adjuster.
http://racetech.com/articles/CartridgeForks.htm
This is the tool you need to retrieve the damping rod:
http://www.motionpro.com/product/08-0337
Damper, damping, potayto, potahto...
bwringer is offline
post #5 of 6 Old 09-28-2016, 09:01 PM
Noted. I wish Suzuki would do a better job with nomenclature.
post #6 of 6 Old 09-29-2016, 10:02 PM Thread Starter
Heck, I'll give it a try.
Current Stable:
1974 Honda CB550
1975 Honda CB750
1981 Honda Goldwing
2000 Hayabusa
2003 V-strom
