Heavy steering - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 22 Old 06-16-2016, 08:42 PM Thread Starter
Heavy steering
Went and test rode an 09 Wee.
The steering felt very numb and heavy like it had a completely flat tire. It was low at 30 psi. No compressor around so going for another test in a few days. Besides tire pressure, anything else I should look at?
It's a fairly new tire, shinko dual sport, not sure which model.
Thanks
Sent from my SM-G900V using Tapatalk
jakes01234 is offline
post #2 of 22 Old 06-16-2016, 08:44 PM
Yup a low pressure Shinko 705 will most certainly do that.
notacop likes this.
post #3 of 22 Old 06-16-2016, 08:49 PM Thread Starter
I hope that was the only issue hahaha. I read all these reviews about how flick able it is and I take it for a quick spin and it feels like I need power steering.
post #4 of 22 Old 06-16-2016, 09:25 PM
Nostromdumbass's Avatar
I swapped dl650's with a friend who had just mounted 705's on his. We were on an infamous twisty mountain road at the time. His bike definitely had heavier steering than my battle wing equipped strom. It took more effort to hold it at peg scraping lean angles than my bike but it stuck well and gave me the confidence to do so. His tires were not underinflated BTW.
I would use the Shinko 705's to assault pavement without reservation, but they do steer heavy.
An original quote by Nostromdumbass;
Facebook: making humanity yearn for the times when people used to talk behind others backs.
Nostromdumbass is offline
post #5 of 22 Old 06-16-2016, 11:50 PM
The front is heavy when new, it's gets better with wear.
post #6 of 22 Old 06-18-2016, 02:16 PM Thread Starter
So I took the bike as a trade this morning. Now that I corrected the tire pressures and have more seat time here is how I can explain what it feel like.
When you turn in, it wants to just drop. I'm not sure if that is the characteristics of the bike? Skinny tires?
I'm getting used to it, but just want to make sure it's normal.
Besides that, the bike is great, brakes are iffy but everything functions as it should.
post #7 of 22 Old 06-18-2016, 02:28 PM
kiwi_outdoors's Avatar
Taken literally - this is light steering, if anything. Its how a bike with new tire and adjusted steering stem bearings may feel after riding a bike with a square tire and tight steering stem bearings.
Maybe you can offer a different description that matches "heavy"?
jakes01234 likes this.
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #8 of 22 Old 06-18-2016, 02:32 PM
NyMeTsFaN912's Avatar
These bikes want to drop because their mass is not centralized. They're known to be top heavy.
-John
NyMeTsFaN912 is offline
post #9 of 22 Old 06-18-2016, 02:39 PM Thread Starter
Okay so let me think some more on it.... it drops in, then to get it back up seems heavy? Which coming off my 919 with brand new tires was not similar, it would always want to stay settled into the corner, not drop in more.
I think I'm just having a learning curve.
post #10 of 22 Old 06-18-2016, 03:25 PM
Check that ride height is matched front to rear. lowering the Strom is a popular mod that is easy to perform and easy to botch. If front is ignored when installing a longer link, the resulting rake change slows up the steering.
Maybe steering bearing adjustment is needed. Youtube is brimming over with how-to check and adjust vids.
Coming to an ADV bike from a race replica (GSXR) may require a new Strom rider to adjust his technique as to the effort needed to flick it in. Stroms should feel similarly agile compared to a sporting standard like the 919.
I'd say that a thorough chassis check up is due, but you should at least have a local Stromtrooper
swap bikes with you or (at least) take yours for a consultation ride.
