Oversize tires? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By strominateacup
post #1 of 7 Old 06-15-2016, 04:31 PM Thread Starter
Question Oversize tires?
sorry, GreyWolf, I had to... but anyways ok, so I'm a new WEE owner, and aside from the 5 pages of nonsense I read, I have a legitimate tire question. I know absolutely nothing about riding except to turn the key, press the button and use controlled methods to change gears while accelerating and braking, I'm not even very good at that... but I just got a bike and was reading, and it says the spec rear on the '08 is a 150/70, but installed is a 170/60... can anyone tell me if there are an risks/advantages to such a tire size, and since I've already put 1500 miles on it, will I notice a big difference if I go back to OEM? thank you!
WaterPig83 is offline
post #2 of 7 Old 06-15-2016, 04:49 PM
I don't like oversize tires. I had a 160/60 on the rear once and it felt vague on cornering. http://dropbears.com/motorcycles/utilities/tyrerim.htm says a 170/60-17 is acceptable but not optimal on 4" rims like V-Stroms have.
post #3 of 7 Old 06-15-2016, 07:22 PM
I got a little time so I reopened, re-titled and moved this thread.
post #4 of 7 Old 06-15-2016, 07:31 PM
pinballer's Avatar
Oversized tires will mushroom. Basically, the rim pinches them together further than they were designed to be, which makes the edges "fall off" steeper than originally intended. To a certain degree, this can help tip in because it makes the tire taller. It can, however, change the geometry enough to affect stability in corners. You'll also likely never get to the edge of an oversized tire (unless you lay the bike down).
2007 DL1000
pinballer is offline
post #5 of 7 Old 06-15-2016, 07:38 PM
strominateacup's Avatar
I agree with Greywolf and pinballer, IMHO just ride it as is until you get your money's worth out of the tyre, then replace it with a standard size. By that time you'll have more idea what type of tyre you want to move on to.
You'll notice some difference in handling anytime you change a tyre, even if its to the same type, as the wear will have changed the profile.
pinballer likes this.
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
post #6 of 7 Old 06-16-2016, 08:20 AM
Brockie's Avatar
I have experimented with different tyre sizes from time to time and seldom found the result to be better overall. Damn those bike manufacturers sometimes get it right.
Brockie is offline
post #7 of 7 Old 06-16-2016, 10:01 AM
Once you get the correct tire size, the handling will seem quicker.
BMW made a 5" and 5 1/2" rim for the 1100S. A friend noticed better handling with the narrower rim.
Makers put a lot of engineering into the product. Folks insist on trying to change stuff empirically and the result is usually less than satisfactory.
Besides, those bigger sizes cost MORE!
notacop is online now
