Still can not find an adjustable centerstand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 06-01-2016, 08:27 AM Thread Starter
Location: Now living in Milton, Delaware and in the winter near Sarasota, Florida
Lowered me bike and I need a permanent centerstand but it must be adjustable. Any help?
manofsteel1 is offline
post #2 of 8 Old 06-01-2016, 09:23 AM
kiwi_outdoors's Avatar
Soupys used to make one
I used it for a while, then threw it out, foot was too small. Instead I made a permanent adjustment to my OEM side stand
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #3 of 8 Old 06-01-2016, 09:24 AM
You'd have to have one specially made. I'll suggest you may want one but you don't need one. Many people are happy with no stand. Others manage a lowered bike with the stand unmodified. Other options include rolling the bike on a board before try a lift or having the stand shortened.
post #4 of 8 Old 06-01-2016, 09:34 AM
Bikeless 4 now
Outbackwack's Avatar
I have a shortened side stand that came with my 2013 650 (it was lowered but I put it back to stock). I'd be happy to swap you side stands if yours is the same. Just an option.
Get busy living, or get busy dying...
http://www.visitedstatesmap.com/image/AZCOCTILINIAKSKYMEMAMOMTNVNHNJNMNYOHPASDTXVTVAWVWY  sm.jpg
Outbackwack is offline
post #5 of 8 Old 06-01-2016, 09:39 AM
Sure your bike needs to be lowered?
post #6 of 8 Old 06-01-2016, 09:46 AM
I had no problems using the centerstand while my bike was lowered and I am not a big buy.
Try this, take your right foot and step down on the stand, getting the bike centered (so you can feel booth legs touching the ground). Then step down hard while leaning over the bike and with your right hand on the rack lifting up.
Mikeys is offline
post #7 of 8 Old 06-01-2016, 10:42 AM
So, if I understand correctly, if the shock is lowered, the center stand becomes more difficult to use.
If I raise the bike, shorter links, it will be even more easy?
My Motech center stand is so easy to deploy now with a full load.
post #8 of 8 Old 06-01-2016, 10:45 AM
That's right to a certain extent. Raise the bike more than a small amount though and the rear wheel won't clear the ground when the stand is deployed. It can even get to the point where the stand won't keep the bike from falling over.
