Mixing tires - help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 15 Old 05-11-2016, 06:56 PM Thread Starter
Hobodog's Avatar
Mixing tires - help
I would like to put TKC 70's on my back tire (2013 650) but the front one's are bad (weird cupping after 3000 miles on my 2011 650). Anyone ever mix tire brands/styles with success? Recommendations to go on the front with a TKC 70 rear?
BlueGlee
Hobodog is offline
post #2 of 15 Old 05-11-2016, 11:53 PM
Mix mix mix away........
trapperdog likes this.
Big B is online now
post #3 of 15 Old 05-12-2016, 01:34 AM
I have TKC 70 on rear, and Shinko 804 front, which replaced a TKC80, and I'm glad i swapped the Shinko is as good as the TKC on gravel and feels better on seal.
yesbut is offline
post #4 of 15 Old 05-31-2016, 10:29 AM
I've got over 70,000 miles on my 2012 DL650. I've only had a front tire the same as the back twice - and that was a different points of tread life front to back, thus never a set starting together. I replace them as needed - unlike some devotees who replace front and rear as a set each time. I find a tire I like, then usually by the time to replace the other, I've gotten interested in trying a different tire, or didn't quite like one thing or another about the last choice. So, mix as you will. Even "matching" tires in a set are different sizes, inflation, and have different jobs on the bike, so the idea of having to match them is not justified in my opinion.
I would suggest you keep it generally the same style of tire to get predictable handling. For example, if you run a popular 80/20 dual sport tire on front, pick a dual sport tire for the rear. A dirt tire rear and sport-street tire front would limit you on both dirt and street.
We're all here, 'cause we're not all there
MrNobody is offline
post #5 of 15 Old 05-31-2016, 10:37 AM
gryphon51's Avatar
I run car tires on the back mostly, so it appears to me mixing is of no issue
2009 DL1000\ Scorpion Racing Skid Plate, Racetech Springs, Acerbis Hand Guards, Givi Engine Guards
Oxford Grips,
ALL BALLS BEARINGS.....Darkside Tire
gryphon51 is offline
post #6 of 15 Old 05-31-2016, 10:46 AM
gryphon51's Avatar
you should join us on the darkside, start getting 25,000 miles to a rear tire
Oxford Grips,
post #7 of 15 Old 05-31-2016, 02:15 PM
Get thee behind me, Satan!
There is some cool-factor appeal to it, and the picture you post looks downright grungy. I think I'll stick with purpose-built tires for now though.
MrNobody is offline
post #8 of 15 Old 05-31-2016, 06:51 PM
Sagebrush's Avatar
Mix away. I ran a Shinko 705 rear with a TKC80 front before for the tread life and still be decent on dirt. Or a Tourance front that wears good and a 705 rear which is cheap and wears good enough for general purpose touring.
Sagebrush is offline
post #9 of 15 Old 06-03-2016, 10:35 AM
lilzip24's Avatar
Has anyone ever ran a Shinko 805 rear and a Shinko 704 front?
2014 DL1000 VStrom
- Khaki
- Madstad windshield brackets
- SW Motech Crashbars
- SW Motech Skidplate
- SW Motech +1 Up/+1 Back Bar Risers
- Barkbuster VPS Handguards
- Shad SH-48 top case
- Shad Sh-36 side cases
- Adventure Tech LED Aux Lights
lilzip24 is offline
post #10 of 15 Old 06-03-2016, 11:12 AM
Similar rubber grip and flexibility helps, but not absolutely required. Key I think is adjusting the pressures to get appropriate handling, and understanding what's going to happen under different conditions. I suspect we all just adapt pretty quickly and unconsciously. I am certainly not going to get rid of an expensive front just because all I can afford is a cheap rear!!!
50 miles from DGMR
2004 DL1000
2009 Versys 650
2014 Moto Guzzi California 1400
toaster404 is offline
