Battle Wing vs. Trail Wing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 11Likes
post #1 of 20 Old 04-27-2016, 11:11 AM Thread Starter
I just got a screw puncture in my rear Trail Wing tire, plugged it, and is holding air, but none of the dealers in town will put a patch on the inside, so I'm thinking of replacement. I do 98% street riding.
Can I put a Battle Wing on the rear (BW502)? It seems to have been discontinued. Or stick with another Trail Wing? If I put a road or touring tire on and keep the stock Trail Wing on the front, will the handling be affected? I am interested in longevity and safety over handling. I would think the Battle Wing is better since it was designed after the Trail Wing was.
rambunkshuss is offline
post #2 of 20 Old 04-27-2016, 11:41 AM
Battlewing is a better tire overall anyways than the Trailwing, by all means feel free to mix tires. Revzilla still sells the Battlewing, and it is still being made as far as I know.
rambunkshuss likes this.
post #3 of 20 Old 04-27-2016, 11:49 AM
Dino M's Avatar
Either one will work just fine. These bikes are pretty forgiving when it comes to handling and tires. After all, they're not a thoroughbred.
Dino M is offline
post #4 of 20 Old 04-27-2016, 09:14 PM Thread Starter
I just got an E-mail from Bridgestone. They suggested I try the NEW Bridgestone Battlax Adventure A40 Motorcycle Tire Rear 150/70-17 Radial It's supposed to be better all-around than the Battlewing and more street/touring oriented.
post #5 of 20 Old 04-27-2016, 09:59 PM
And a helluva lot more expensive too.
post #6 of 20 Old 04-27-2016, 10:29 PM
Our V2 came stock with BW501/502 and they are a VERY good road tyre (tire!) I had just traded our SV1000 running Pirelli Angel GTs, and riding the V2 fast on a very bumpy twisty road I reckon I was as fast as I could ever have been on the SV. My friend on a hot TLS1000 reckons he was at the limit (due to the bumps) basically I,m saying I have been riding the V2 like a sportsbike and the BW501/502 did not limit me. only scraping hard parts did!
On dirt roads they are acceptable but they do squirm around. I have trailwings atm and they are much better in the dirt (maybe I,m getting more comfortable in the dirt?) and I did a fastish ride on the weekend and I had no complaints about the trailwings.
If your 90%+ on sealed roads the BW are the pick they are underated IMHO. AND they last for ages! We got 12,000 ks from the rear ,mostly 99% 2 up and many thousands of K,s with a shitload of luggage. I reckon the front would have done 18,000ks
FWIW if your tyre was plugged correctly I wouldnt be concerned about if loosing pressure unexpectedly, a rope plug for example isnt gonna just pop out. If/when you take that tyre off, have a look at the knot inside where the rope plug is You,d be more likely to get another puncture than have the repair fail
richlandrick and rambunkshuss like this.
Paul and Dixie and our V2
DL1000A 2015. SW-Motec crash bars and skid plate,Givi Airflo screen,Givi rear Hugger,Factory low seat,Barkbusters with Storm guards,Factory Tank Protector, Factory centre stand,RadGuard Radiator Guard,home made top box adaptor plate with poverty top box,Factory hard panniers,Zumo390LM,TKC70's,windshield lowered 50mm with custom mounting plates,motopressor tyre inflator,Virgins breath in the tyres,Barrett exhaust,AWESOME rider and pillion.
We2V2 is offline
post #7 of 20 Old 04-27-2016, 10:44 PM
aka Rick in Alabama
basketcase's Avatar
Originally Posted by We2V2 View Post
... snip ...
What he said about properly plugged tires. I'm running one on the back my my BMW and another on the pickup truck.
Neither has failed.
Current ride: 2001 GL1800; Gone away: 5 BMW's, 4 Honda's, 3 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." -Marcus Aurelius
basketcase is offline
post #8 of 20 Old 04-28-2016, 12:30 AM
Sappuer's Avatar
Ran a plugged rear for a summer and half. Only reason for the switch was wear out. I went with BW front and rear on my 04 wee. In the last year I have liked them a lot.
Sappuer is offline
post #9 of 20 Old 04-30-2016, 07:16 PM
NeverSatisfied's Avatar
When my rear TrailWing wore out I replaced it with the Battlewing. There was no problem with that combo until the front TW started to wear out. So I also put a BW on the front. Now, I don't find the V-Strom to be that confidence-inspiring on gravel anyway, due to its higher center of gravity compared to some other bikes, but, at least in my opinion the BattleWings handle better on gravel than the TrailWings. And there are a couple of roads near Marietta, Ohio that allowed the BattleWings' grip to scrape a peg a time or two, so I'm quite happy with them as a good general-purpose tire. Also, there are times when I've gassed it pretty hard turning from a stop, and the rear does not break loose dramatically but seems to be predictable- you may feel it slip ever so slightly but nothing scary. (Although that probably also has a lot to do with the V-Strom's nice smooth power delivery.)
That said, I'm planning to get a little "dirty" with the Strom, and have a set of Mitas E-07 Dakars waiting in the garage! But if not for that I'd stick with the BattleWings for as long as they are available.
2012 DL650
2018 DR650
NeverSatisfied is offline
post #10 of 20 Old 05-23-2016, 04:29 PM Thread Starter
I'm wondering if the hole that was made by the screw weakened the cordage and will eventually fail from stresses.
