rear tire size - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 04-12-2016, 12:49 PM Thread Starter
falcon4's Avatar
rear tire size
Can you go to a 160 on the rear tire on this std rim?
If you can, is there any reason not to, like handling or safety?
thanks,
DL1000 Adv
from
KTM SMT990, KLX250, KTM250 exc, FZ1, DR650
FJ1200, XT600, CL200, CT70
falcon4 is offline
post #2 of 6 Old 04-12-2016, 01:44 PM
Yes you can put a 160 on the rear, other than how it MIGHT make the bike feel different under turning situations and the higher cost of a 160 vs. a 150 there should be not real issues.
You will need to accommodate the difference in tire height if you go from a 150/70 to say a 160/70 it will make the bike turn in quicker due to the rear end being raised.
A signature
sdmdm8 is offline
post #3 of 6 Old 04-12-2016, 01:49 PM
stromer's Avatar
Another thing, I would think you would limit your choice of tires when changing.
just give it a little gas, it will be ok !!!
stromer is offline
post #4 of 6 Old 04-12-2016, 02:04 PM Thread Starter
falcon4's Avatar
Good points you each mention and that is what I was looking for...
falcon4 is offline
post #5 of 6 Old 04-12-2016, 03:19 PM
All V-Stroms have 4" wide rear wheels so the question applies to all models. I had a 160/60 Michelin Pilot Road rear tire on my bike once and and the more extreme the lean angle got, the more vague the bike felt. While the wider tire is in the acceptable range for a 4" rim, it is not optimal. The change in the angle the rubber makes with the road in a turn when the bead is narrower did not inspire confidence.
post #6 of 6 Old 04-12-2016, 09:44 PM Thread Starter
falcon4's Avatar
Thanks, sounds like the many reasons not to, clearly outweigh my preference for wider tires for appearances....
DL1000 Adv
from
falcon4 is offline
