ALTERNATE Tire size?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By greywolf
  • 1 Post By 2013VEE650
post #1 of 9 Old 03-13-2016, 04:56 PM Thread Starter
2013VEE650's Avatar
Question ALTERNATE Tire size??
The spec'd FRONT tire for my '13 650 is 110/80 19.
I am interested in the Dunlop TR91 series and although the REAR is available, all the normal ONLINE outfits are "Out of Stock" on the conforming OEM size above.
I an get a 100/90 - 19 "In Stock" which I believe is a little 'taller and narrower'. Anyone know the pros and cons of using a non specific size on the front end?
2013VEE650 is offline
post #2 of 9 Old 03-13-2016, 05:18 PM
Here is a chart. Rim to Tyre Application Chart
Narrower tires in the permissible range will likely not last as long while wider tires in the permissible range will last longer but may feel vague at greater lean angles. The wheels are 2.5" in front and 4" in the rear.
2013VEE650 likes this.
post #3 of 9 Old 03-13-2016, 05:59 PM Thread Starter
2013VEE650's Avatar
Thanks for the reply, GW.
Looking at the CHART, I don't see the 110/80-19 listed there at all for a 2.50 front. Do I have the OEM tire size wrong at 110/80-19 ?
The 100/90-19 is there though ???
post #4 of 9 Old 03-13-2016, 06:48 PM
The chart used to show it. I don't know why it's gone.
post #5 of 9 Old 03-13-2016, 09:34 PM
Brockie's Avatar
The 110/80 tire is 88mm high where the 100/90 tire is 90mm high, and one is 10mm wider that the other.
You might find the narrower tire to turn in a little quicker and be slightly more stable in gravel. Slightly.
Brockie is offline
post #6 of 9 Old 03-14-2016, 04:23 AM Thread Starter
2013VEE650's Avatar
So the difference between 110/80 and 100/90 is that the 100 tire is just 1cm narrower but 1 cm taller. I can live with that. Thanks for the input
Brockie likes this.
post #7 of 9 Old 03-14-2016, 08:12 AM
Brockie's Avatar
1 cm narrower and 2 Millimeters taller. Way less than 1/8th of an inch.
Brockie is offline
post #8 of 9 Old 03-14-2016, 05:13 PM
Spec's Avatar
Tire Diameter Calculator
Spec is online now
post #9 of 9 Old 03-14-2016, 06:07 PM
Banned
i did something like that once. i didnt like. through the handling off. had to change back to stock size for fix.
V-Strom (Suzuki DL1000) | Fuelly
JRWalker is offline
