rear shock help dl1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Farmer Strom
post #1 of 7 Old 03-03-2016, 04:37 PM Thread Starter
Class86act's Avatar
installed my front suspension and now I'm on to the rear, i have the rear shock out of the bike, unsure of how to disassemble it, i can't seem to find a thread about it either. maybe someone can point me in the right direction? 2007 dl1000
1977 Suzuki gs750 (passed down from my grandfather)
2007 DL1000 16/43 sprockets, speedoDRD, happy-trails aluminum panniers, givi crash bars, ricks fork brace and rear wheel spacer.
2008 Yamaha yz450f
2004 Yamaha yfz450 way too much invested in it
Class86act is offline
post #2 of 7 Old 03-03-2016, 06:13 PM
pinballer's Avatar
Stock rear shock isn't serviceable. Well, it is, but it's not a DIY project for the weekend handyman.
2007 DL1000
pinballer is offline
post #3 of 7 Old 03-03-2016, 07:01 PM Thread Starter
Class86act's Avatar
I know that, and I know it is 100% possible to change the spring on it, I'd say a weekend handyman is a very large understatement. Been a mechanic on and off my entire life and I service and modify all my vehicles other then engine internals.
2008 Yamaha yz450f
post #4 of 7 Old 03-03-2016, 07:18 PM
pinballer's Avatar
"Disassemble" usually refers to rebuilding when referring to shocks. I guess you weren't clear of your intentions, and I made an assumption. Yes, the spring can be removed.
Remove the shock, back the preload all the way out, loosen the screw (Allen) on the preload cylinder, press down on the preload cylinder, then remove the snap ring.
2007 DL1000
post #5 of 7 Old 03-03-2016, 07:41 PM Thread Starter
Class86act's Avatar
Thank you so much! I guess my post was a bit vague. I knew it had to be something simple like that. Thanks again man.
2008 Yamaha yz450f
post #6 of 7 Old 03-03-2016, 07:44 PM
pinballer's Avatar
Not a problem, and glad to help. The Allen screw keeps things aligned properly. Might not be a bad idea to make a reference mark before you loosen it so you can drop it right back in the same spot without having to fiddle with it.
2007 DL1000
post #7 of 7 Old 03-05-2016, 10:57 PM
Farmer Strom's Avatar
Here is the link to replace the rear spring with a hyperpro. Many thanks to the UK Strom site.......
[0005] Changing the Rear Spring on the DL1000
Cheers FS
pinballer likes this.
Did own - 03 V Strom. Racetech springs gold valves, 'shocktreatment' rebuilt rear shock (spring and valving), Pro taper high ATV bars and Storm Barkbusters modded from honda transalp, eastern beaver power outlet headlight relay mod and fuse block, power commander, givi top case and panniers, staintune exhaust.
Farmer Strom is offline
