Clunk! Crack! WTF??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Big B
post #1 of 6 Old 02-24-2016, 10:16 PM Thread Starter
teevee's Avatar
so, yeah, i'm a bit heavier than the V's shock/spring are designed for, but every once in a while when hitting even a small bump/pothole, the rear end feels like i have a flat tire. and always, the air pressure is fine (36-40).
i do plan on rebuilding the shock and getting an appropriate spring but until the $$$$ are available for that, any ideas on why this is happening?
'08 DR650, '07 DL1000
teevee is offline
post #2 of 6 Old 02-24-2016, 10:30 PM
You ride a 9 year old bike which is under sprung for your weight......it is worn out.
Spec likes this.
Big B is online now
post #3 of 6 Old 02-24-2016, 10:34 PM
Hank122's Avatar
I wonder if your preload adjuster needs to be reworked.? Can you see any space above the spring when it's cranked up all the way?
https://www.stromtrooper.com/maintena...ster-pics.html
Henry
"Rock bottom will teach you lessons that mountain tops never will..."
2016 V-Strom DL650 (red) 'Sweetness'
2011 V-Strom DL650 (white)
Hank122 is offline
post #4 of 6 Old 02-26-2016, 07:08 PM
bwringer's Avatar
Agreed -- your shock's pooped, and your preload adjuster might be pooped as well.
bwringer is offline
post #5 of 6 Old 02-26-2016, 08:35 PM Thread Starter
teevee's Avatar
except my 9 y/o bike has only 23,000 miles on it so it's really only about 2.75 y/o.
if this happened every time i hit a bump or pothole i wouldn't have asked the question. but as i quite clearly said, "every once in a while..."
i will take a look at the preload setting and see if that makes a difference
teevee is offline
post #6 of 6 Old 02-27-2016, 02:59 PM
The purpose of the preload is to get the loaded bike in about the middle of its suspension travel. It sounds like you need to raise yours or maybe rebuild the hydraulic preload adjuster (just a leaky o-ring).
Do this--turn the preload adjuster and see if the top spring mount on the shock raises and lowers. If the knob won't turn, search this site for ways to free it up. If it turns but the mount doesn't move, you need to fix that leaky o-ring. If it raises & lowers, you're ready to set the sag.
Raise the rear wheel off the ground and measure from the axle to a spot on the rear fender. You probably need a helper. Get on the bike, straight up & down, tip toes just brushing the ground, and have the helper measure the same points again. You want about a 40 mm change in the measurement. Crank the preload knob to get that 40 mm. Measure again to be sure.
Same idea for the front. Use a cable tie around the inner fork tube. Front wheel off the ground, slide the tie next to the seal. Get on, jiggle a bit to settle the suspension, tip toes on the ground, get off, wheel in the air, measure how far the cable tie got pushed down the fork tube. Use the screw slots in the top of the forks to make a change to get the tie to a 40 mm movement, test again.
