Flat repair kit question. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 16Likes
post #1 of 28 Old 12-19-2015, 08:41 PM Thread Starter
So now I'm putting together a good tubeless tire plug repair kit. How many of the CO2 cylinders will it take to fill fix and refill a rear tire? I know there are a lot variables doing this but someone here has done this and could give me an idea of how many.
In the shed- 07 DL1000, 13 ZG1400, 16 VFR1200X
smoothbored is offline
post #2 of 28 Old 12-19-2015, 09:13 PM
kiwi_outdoors's Avatar
bad idea
buy a 12V compressor, remove the case, tuck the compressor under your seat. Adjust electric connections to suit your bike (ciggy lighter, alligator clips, SAE fitting, Powerlet etc etc). If you plug repair method needs a blade - make sure you have a blade.
Big B likes this.
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #3 of 28 Old 12-19-2015, 10:51 PM
eagleeye's Avatar
CO2
Well, I have done it and it doesn't always work the first time so I'd have a couple, but actually I'd probably take 4, after all they are small. Getting to bead up was the problem.
Now I use a 12v pump, or at least take it with, never have had to use it.
Actually I was thinking about throwing the CO2 thing in the bag also.
2009 Suzuki DL650
2005 Yamaha RSTD
2002 Triumph Bonneville
1980 Yamaha XS650 chopper
The Best Bike is the Bike You Like
eagleeye is offline
post #4 of 28 Old 12-19-2015, 11:01 PM
Rolex's Avatar
Putting a ratchet strap around the tyre circumference and winding it tight will help with setting the bead and the straps make great tow ropes should a tow be required.
PTRider, uncaged and Outbackwack like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #5 of 28 Old 12-19-2015, 11:06 PM
BanditDave's Avatar
My $10 air compressor fits under the seat along with the repair plugs and tools. If I use this compressor just once I will replace it with a new one.
Personally, I suggest the best place for the CO2 cylinders is in the rubbish bin
_________________
BanditDave
Hervey Bay, Queensland, Australia
2015 Suzuki DL650AL5
x 2014 Honda CBR650F
x 2009 Suzuki Bandit 1250
x 2006 Suzuki Bandit 1200
x 2004 Suzuki VZ800 Marauder
BanditDave is offline
post #6 of 28 Old 12-19-2015, 11:28 PM
V-Tom's Avatar
I use the worm-type of plug with the insertion tool, rasp, "worms", air compressor and alligator clip cigarette lighter adapter sitting under my seat along with my switched fuse box, autocom AVI-Pro, manual, multi tool, manual and some other odds and ends. I've fixed 6 or 7 flats on the road. All but one on my bikes, the other on a fellow rider's.
..Tom
Big B and trapperdog like this.
SMIDSY detailed report.
V-Tom is offline
post #7 of 28 Old 12-20-2015, 11:13 AM
randyo's Avatar
one more than you have
a small compressor takes up less space
pumping up tires with greenhouse gas is bad for the environment
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #8 of 28 Old 12-20-2015, 06:23 PM Thread Starter
I'm not concerned about greenhouse gas, just might burn a few logs to keep warm.
StarChamp and eagleeye like this.
post #9 of 28 Old 12-20-2015, 06:33 PM Thread Starter
I guess this is just one of those things I'd be better off finding out myself. thanks all.
post #10 of 28 Old 12-20-2015, 09:49 PM
I have enough experience with CO2 on mountain bikes to feel comfortable saying it is quite a few. Especially if you mean the standard little cartridges. If you are going to give it a go, look for the much bigger type CO2s that I think bike shops sell as"Big Air". I have wondered what might be bought at a place like AirGas in the way of a small aluminum tank of air or CO2. Hospitals have all sorts of small tanks of pressurized gases with regulators. Been meaning to look into that for a while for my on/off road adventures where I'd like to air down. Much faster than a compressor, and it has that sudden present that is sometimes necessary to pop a bead on. Limited number of uses though.
Bentwee is offline
