V strom problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 12-19-2015, 07:51 PM Thread Starter
V strom problem
Hey guys,
I just got some hedienau k60s installed on my bike and I've been getting a whining noise coming from the front of the bike at highway speeds, only when I'm not on the throttle. Also at very slow speeds less than 5 when coming to a stop the bike shakes left to right slightly. This happens either when I'm applying the brakes or I'm coasting to a stop with the brakes. Could it be the new tires or is there something else wrong?
Thanks
Sbenson619 is offline
post #2 of 16 Old 12-19-2015, 08:26 PM
blaustrom's Avatar
Google for tire noise
I am sure that's what it is if there was nothing wrong before the tire change.
blaustrom is online now
post #3 of 16 Old 12-19-2015, 08:40 PM
Tires. Ignore it.
yesbut is offline
post #4 of 16 Old 12-20-2015, 12:52 AM Thread Starter
Would that also explain the wobble at low speeds?
post #5 of 16 Old 12-20-2015, 01:32 AM
mr_anonymous's Avatar
Personally, I would not run less than 36 psi in the front.
Also adding a wee bit of preload to the front will sometimes settle a little bit of nervousness.
But firstly confirm there is no underlying problem that has arose by coincidence at the same time of fitting new tyres.
A more aggressive tread pattern will most likely account for the noise you hear and might also account for the slight shake you experience but I would still check tyre pressures, wheel and headstock bearing's.
mr_anonymous is offline
post #6 of 16 Old 12-20-2015, 03:00 AM
strominateacup's Avatar
That's exactly what mine did when I put Heidenaus on it. The handling is also very different to the OEM tyres, it'll drop into turns, felt unsafe to me at first but after a couple of hundred km I've got used to it. Much nicer in the dirt. I recommend higher front pressure than standard. You have to put up with the highway noise and front end 'wobble' at very low speed.
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
post #7 of 16 Old 12-20-2015, 03:16 AM
And that's why I will never use Heidenaus for street use again.
Rick123 is online now
post #8 of 16 Old 12-20-2015, 01:50 PM
MontanaGuy's Avatar
I use them and love the K60's. Yes, they whine and sing (telling me how happy they are!). But, have no issue with a slow speed wobble, or high speed either. Something else is up. As far as the noise, I use ear plugs!
Current Motorcycles
2007 Wee
2010 BMW S1000RR
2001 Suzuki SV650S
2005 Vee R.I.P.
MontanaGuy is offline
post #9 of 16 Old 12-20-2015, 02:11 PM
Something else is not up, it is your new tires.
post #10 of 16 Old 12-21-2015, 09:25 PM
Texan's Avatar
Did you read reviews before you bought them? They are notoriously noisy tires?
2016 BMW R1200RS
2016 Suzuki GSX-S1000F
2013 Suzuki DL650.. SOLD!
2017 Suzuki DL650 as soon as they hit the sales floor.
Texan is offline
