2 questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 09-26-2015, 12:37 PM Thread Starter
So Cal DL's Avatar
2 questions
1. Will a 160 70 17 fit my 04 vee?
2. Do you know anyone in orange county ca who stocks 150 70 17
Looking for a road tire
Randy
04 Vee
PCIII DEKELVIC SLIP ON EXHAUST,K&N AIR FILTER,TREKKER 33 SIDE CASES, BESTEM TOP BOX, FORK BRACE, PEG LOWERING KIT, FLEXX BARS, NELSON RIGG TANK BAG, GIVI CRASH BARS, MADSTAD WINDSHIELD BRACKETS, MOOSE RACING TALL SHIELD
So Cal DL is offline
post #2 of 9 Old 09-26-2015, 12:48 PM
I'd imagine almost any dealer would have a road tire in the size.
Motorcycle Tire Center - Repair & Performance Bike Shop
That popped up on a search.
post #3 of 9 Old 09-26-2015, 12:51 PM Thread Starter
So Cal DL's Avatar
Yeah ive called around . Motorcycle tirecenter opens at 10 am.im calling then
thanks
Randy
04 Vee
post #4 of 9 Old 09-28-2015, 07:10 PM
jsp
jsp's Avatar
I'm a little late to the party. I'm in North San Diego County, maybe 65 miles from you. I stock the Bridgestone T30R size 150/70ZR17 for $122 plus $25 for mounting and balancing. This is a great street tire for adventure bikes, great price, great traction and long wear. As far as replacing the tire with 160/70ZR17, I don't recommend going oversize with sport or sport touring tires. a 160's ideal rim is 4.5 inches wide but you have a 4.0 inch wheel. The profile of the 160 gets pinched on a 4.0 inch wheel, handling and stability suffer.
john
jsp is offline
post #5 of 9 Old 09-28-2015, 09:56 PM
OCADVR's Avatar
I sent you a PM.
OCADVR is offline
post #6 of 9 Old 09-29-2015, 12:50 AM Thread Starter
So Cal DL's Avatar
Thanks guys. I ended up ordering a tire it will be in tomorrow went with the road 4 since that what it is now
Randy
04 Vee
post #7 of 9 Old 09-29-2015, 08:40 AM
Good luck. I had a 160 on the back once when I did a tire change on the road and the shop didn't have a 150. I hated it. The more lean I had, the vaguer it felt.
post #8 of 9 Old 09-29-2015, 08:55 AM Thread Starter
So Cal DL's Avatar
Gw I went with the stock size. After I went back through some old threads and some of your old responses. Once I discovered the ideal rim size for the 160 was 4.5" that question was answered
Randy
04 Vee
post #9 of 9 Old 09-30-2015, 10:06 AM
About tire size, A friend with an 1100S BMW had the 5.5 rim and proper size tire for that. He changed to the standard 5" rim and proper tire for that size and was very pleased with the better handling characteristics. Much smoother in transition, easier to initiate the turns.
Mo Bigger isn't necessarily mo bettah!
Could be that the difference in the weight of the larger tire may be noticed too.
