Installing Cogent shock - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 09-12-2015, 03:55 PM Thread Starter
Working on installing a cogent shock in my '12 650. Here's a silly question: does it matter which way it's installed? Does that screw facing to the right at the top need to face front/back, or does it not matter? Thanks.
sitzus is offline
post #2 of 7 Old 09-12-2015, 04:27 PM
Rick505's Avatar
I don't believe it matters but certainly a question that they could answer for certain.
Rick505 is offline
post #3 of 7 Old 09-12-2015, 06:23 PM Thread Starter
Sure, but they're not open on weekends and I'm an impatient bastard. =)
sitzus is offline
post #4 of 7 Old 09-12-2015, 10:21 PM
did mine
It does not matter
croissant_warrior is offline
post #5 of 7 Old 09-12-2015, 10:51 PM
kiwi_outdoors's Avatar
access
as long as you can access the screw, once the shock is installed, IF you need, to, then orientation does not matter
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #6 of 7 Old 09-14-2015, 05:15 PM Thread Starter
Much obliged; thanks.
sitzus is offline
post #7 of 7 Old 09-17-2015, 05:28 PM
mr_anonymous's Avatar
Is there a rebound adjuster on the bottom of the shock?
Is access hindered by left or right orientation of the shock?
mr_anonymous is offline
