Rear Axle Grease - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By PTRider
post #1 of 9 Old 07-20-2015, 10:02 PM Thread Starter
tenny80's Avatar
Rear Axle Grease
Well I used the "zip tie" method tonight to replace my rear tire... my pocket book didn't want to pay a shop 80 bucks to install it and have to piss around with leaving the bike there all day.
Everything went great, my only question though is regarding the rear axle. It didn't have a drop of grease on it... the bearings had grease, but the axle was bone dry. Is that normal (it's a new bike, first tire change).
2018 Vstrom 1000
tenny80 is offline
post #2 of 9 Old 07-20-2015, 10:12 PM
Kurgan's Avatar
Unfortunately, pretty normal. Just take a dab of grease and smear it on the axle, just the thinnest of coatings is sufficient.
Jim
Kurgan is offline
post #3 of 9 Old 07-20-2015, 10:32 PM
Doesn't need it. It's stainless steel as evidenced by the tendency for it to gall to the nut.
post #4 of 9 Old 07-20-2015, 10:35 PM Thread Starter
tenny80's Avatar
Well grease hurt it any?
2018 Vstrom 1000
tenny80 is offline
post #5 of 9 Old 07-20-2015, 10:58 PM
A little grease won't hurt anything.
post #6 of 9 Old 07-21-2015, 12:52 PM Thread Starter
tenny80's Avatar
OK good, because I lubed it up
2018 Vstrom 1000
tenny80 is offline
post #7 of 9 Old 07-21-2015, 01:54 PM
I lubed mine up under the advice of a bike mech , both the nut and axel got striped on mine and they were torqued correctly made of cheese I think
revapi is offline
post #8 of 9 Old 07-21-2015, 02:20 PM
Once again, stainless steel fasteners under high pressure can gall, or cold weld. Taking a galled nut off the axle destroys the threads as the threads on both parts unite until broken off and stay on one part or the other. It gets really interesting when the outboard threads stay with the axle and the inboard threads stay with the nut. Then the nut has to be cut off to release the axle. https://www.stromtrooper.com/general-...ad-galled.html
This thread is about the axle though, not the threads. Anti seize on the threads and using 80% of the specified torque to account for the lubrication effect is an excellent idea.
post #9 of 9 Old 07-21-2015, 05:57 PM
A smear of grease on both axles make the next removal easier.
JackinCT likes this.
