Finding the right height - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 07-08-2015, 09:09 AM Thread Starter
This may be a dumb question but what is the optimal height to have the bike at? I ride a 2014 wee and am 5-8. I had the stock seat shaved down a bit to make it more comfortable and get me a little closer to the ground but still seems a bit high. I can't flat foot with both feet. Can't even get the balls of my feet on the ground at the same time. I can either flat foot my left with a slight lean or I can do tip toes on both feet. Do I need to lower the bike more? How?
roadrat is offline
post #2 of 8 Old 07-08-2015, 09:21 AM
My favorite article on lowering is this one. Raising + Lowering Links--Review, Installation and Pics
Be very aware of the dangers in lowering too much. Beyond 21mm in front and 28mm in back, damage can occur if the suspension bottoms out unless suspension travel is also limited in the lowering process.
post #3 of 8 Old 07-08-2015, 09:43 AM Thread Starter
I'm generally not a fan of modifications to frame on vehicles. What about smaller tires or other options to lower?
roadrat is offline
post #4 of 8 Old 07-08-2015, 09:58 AM
You've already done the seat. Additionally, the rubber bumpers under the seat can be thinned. Really though, V-Stroms in general and the Glee in particular can be lowered by using longer dog bone links in back and by bringing the fork tubes up in front without affecting handling negatively with the sole exception of less clearance. Unless you're playing boy racer, leaning the wrong way in a turn or going off road in gnarlier conditions than the bike was designed for, that shouldn't be an issue. Mine is lowered 19mm or 3/4 inch at both ends, mostly to make it easier to get on and off a table lift and make backing up easier on my old knees. If anything, I like the handling better with the lower center of mass.
post #5 of 8 Old 07-08-2015, 11:20 PM Thread Starter
I read the article recommended above and also checked out some other posts bone I'm more confused. Some people seem to think that it is fine to be on just tip toes. The only reason I care is sometimes I have to stop and turn 90 degrees in the hills and the ground is off camber so I end up really tilted. But maybe I just need to get better. Should I hold off on adjusting height for now or is there a clear need to get both feet more on the ground?
roadrat is offline
post #6 of 8 Old 07-08-2015, 11:41 PM
That's really a personal decision. I don't want to have to dismount to back the bike up and I have no problem with ground clearance. Not being able to get my heels down in normal riding doesn't bother me though.
post #7 of 8 Old 07-16-2015, 11:48 PM
I fitted adjustable dog bones made by a firm here in Oz, bit more expensive but you can play with them to your hearts content. it's an ebay store
name: rated r custom motorcycle parts (sorry, doesn't want to paste the link)
dpen is offline
post #8 of 8 Old 07-17-2015, 05:28 PM
BanditDave's Avatar
Here's a clever program that allows you to change various parameters and see the result
Motorcycle Ergonomics
_________________
BanditDave
Hervey Bay, Queensland, Australia
2015 Suzuki DL650AL5
x 2014 Honda CBR650F
x 2009 Suzuki Bandit 1250
x 2006 Suzuki Bandit 1200
x 2004 Suzuki VZ800 Marauder
BanditDave is offline
