What tire pump/repair kit should I look for? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 28 Old 05-19-2015, 11:06 AM Thread Starter
I did a search and didn't see a discussion about this. I see reference to worms and plugs, but don't know which is better and didn't find any discussion about pump to look for.
I'm planning my first motorcycle road trip. I hadn't considered a tire repair kit or pump until I started looking for a packing list to use as a reference. I don't do any off road riding on my Vee. I'm riding from southern Utah up to SLC area to meet a brother and then we are riding across I-80 to meet with dad in the Bay Area (about 1000 miles for me just to get to our "starting point"). We plan to spend a couple days going down the coast of California.
All in all....for me it will be about 3000 miles in 5 or 6 days. I know for some that is nothing. For me...and on my first trip...that is a lot! I mainly ride around town to work and back. Most years I don't put 3000 miles in the whole year, so this is big.
Any direction on the pump/repair kit and anything else would be greatly appreciated. I'll keep searching the forum for ideas.
bsevans5 is offline
post #2 of 28 Old 05-19-2015, 12:17 PM
SECoda's Avatar
I have the Stop N Go w/ mini compressor that uses mushroom plugs and a Slime worm kit depending on the nature of the hole. I used the stop and go twice now and it works well but the plug is only temporary.
SECoda is offline
post #3 of 28 Old 05-19-2015, 12:49 PM Thread Starter
What would dictate when you use which kind? Any recommendation for compressor/pump?
bsevans5 is offline
post #4 of 28 Old 05-19-2015, 01:27 PM
Downs's Avatar
All I've ever used are the rope/worm type plugs. I've plugged some pretty bad holes with those sometimes using two or three to repair a sidewall puncture on a Jeep tire. I've used them countless times on motorcycles for nail and screw punctures and continued to ride that tire until the end of it's life.
Use what you like but the rope/worm solution is the cheapest and used by many and seems to work the best short of pulling the tire and having a patch placed inside the tire.
I've had countless miles on plugged tires and never had one leak on me.
As for the compressor to use just go to Wal-Mart and grab the cheapy off the shelf. I use a high volume harbor freight compressor which takes up a bit more space than the typical SLIME pump but since I air down for dirt and air back up afterwards I wanted something that was a little faster. No sense in spending big money on this item.
Downs is online now
post #5 of 28 Old 05-19-2015, 02:09 PM
SECoda's Avatar
A for a small round hole like nail the mushroom works pretty well. For a cut like a knife I would use one or more worms (and have in car tires). The Stop N Go mini-compressor works pretty well. The whole Stop N Go kit w/ compressor was $54 on Amazon. The Slime worm kit is about $10.
SECoda is offline
post #6 of 28 Old 05-20-2015, 10:34 AM
Spec's Avatar
I use the smallest Slime pump fits under the seat.
I also use the Slime repair kit with the black strings but I've found that the Slime red strings work better. They are a bit larger diameter but better quality, that's probably why they don't come in the kit!
Connected a waterproof 12v cig receptacle and have it stuck in front of the battery/electrical stuff.
Bought everything at WalMart.
eagleeye likes this.
Spec is offline
post #7 of 28 Old 05-20-2015, 11:24 AM
Allan's Avatar
Does anybody bother with both the mushroom plugs and worms?
"Aqaba is over there, its only a matter of going." -Lawrence
2007 V-Strom 650
Allan is offline
post #8 of 28 Old 05-20-2015, 01:12 PM
Axeman's Avatar
CyclePump
Checkout the "CyclePump" at this linky.
BestRest Products, LLC
I have one, used other brands and they always broke within a short time. It is a bit pricer than other brands but it appears well built and comes with a multi-year warranty. I not only use it on my motorcycle tires but also my car tires.
Highly recommended.
Skew likes this.
K9 Vee
Farkles: SW-Motech bash plate and center stand; PCV; RR-Peg lowering kit, mirror extenders, Rear axle shim kit, GPS Mount; Super Brace; National V-Stream wind screen; 17/43 Sprockets; Ivans TRE; TouraTech 35L panniers; Givi 52L top case; LeoVince SBK exhaust; Corbin seat, Rox risers, Gailer SS clutch and brake lines; Madstad bracket; Grip Puppies; Cramp Buster; Werks clutch basket
Axeman is offline
post #9 of 28 Old 05-20-2015, 08:15 PM
Downs's Avatar
Never bothered to carry anything but the "ropes". Time tested tire repair method. No sense in carrying multiple ways to plug a tubeless tire.
Downs is online now
post #10 of 28 Old 05-21-2015, 03:07 AM
RichWee's Avatar
I use Nealey ropes, and the motopumps compressor. It costs a little more but I think the quality of the hose, connector, and pump is worth it. Fits nicely under the seat, and will inflate from totally flat in 3 to 4 mins without overheating. I carry a 3/4 inch pvc T to put over the handle of the insert tool, giving a good surface to push on to get it through the tire.
RichWee is offline
