I am stumped slow leak on my DL1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 04-17-2015, 11:29 AM Thread Starter
Have a leaky rear tire add air and an hour later it is 10 15 psi down. Last night I sprayed soapy water all over the tire and could not find any air leaks. Checked the valve stem also.
These are a set of Anakee lll front and rear with 5373 miles on them. They are showing signs of cupping and wear. But still have lots of rubber left on them.
Anyone have any thoughts?
Scott
2008 DL1000
Power Commander USB Cheffs custom map
K&N airfilter
Leo Vince Exhaust
Race tech springs
Werks clutch basket
1" up and 1" back risers
Mototech fork brace
Gaffer Brake lines
Givi side and top cases
Givi tall screen
Givi engine guards
Anakee lll tires
src350z is offline
post #2 of 13 Old 04-17-2015, 11:31 AM
Yup.....replace it.
Big B is online now
post #3 of 13 Old 04-17-2015, 11:36 AM
Did you spray soapy water on the bead area? What about the rim? They have been know to develop fractures. If air is escaping, the soapy water will find it.
realshelby is offline
post #4 of 13 Old 04-17-2015, 04:25 PM Thread Starter
leaky tire
I checked the bead all around both sides but I did not check the rim. I sincerely hope it is not that! I just ordered a new set of BT45's I don't ever hit the dirt on the strom.
2008 DL1000
K&N airfilter
Leo Vince Exhaust
Race tech springs
Werks clutch basket
Mototech fork brace
Gaffer Brake lines
Givi tall screen
Givi engine guards
Anakee lll tires
src350z is offline
post #5 of 13 Old 04-18-2015, 12:35 PM
BC Rider's Avatar
Tale the wheel off. Put 8 in of water in the tub and roll it around in there. Best done when the misses is out of the house.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #6 of 13 Old 04-18-2015, 12:54 PM
Mr. Black's Avatar
Yup, when you've reached the point of frustration it's bathtub time. You WILL find it that way. Goes without saying, try not to submerge your bearings.
Steve,
2014 Vee2.
Givi Airflow, Givi crash bars.
Oxford Adventure grips.
Hindle Carbon Muffler.
Touratech handguards, Touratech skid plate.
Rox 1"x1" risers, RK Gold X-ring chain.
Mr. Black is offline
post #7 of 13 Old 04-18-2015, 12:58 PM
I had a similar slow leak a few years back. Eventually, after many revolutions of the tire I found tiny bubbles. There was a small staple that had worn down level with the tread. How something so small could go clear through was puzzling.
My suggestion is to soap it again & look closely.
2007 DL 650 with assorted upgrades
Solo is offline
post #8 of 13 Old 04-20-2015, 04:20 PM
Penmaker's Avatar
Finish nails can submerge below a visible level on the tread. Sometimes the only way to see a nail is from the inside of the tire.
Penmaker
04 GL1800A - Traxxion suspension
11 DL650 ABS white - Lowered, Risers, Richland Rick stuff, Sgt seat, Madstad
Penmaker is offline
post #9 of 13 Old 04-20-2015, 04:33 PM
My recent experience with this issue was the little valve within the valve stem. I think I bent it putting air in. Could have just been a little spec of dirt. Who knows? Try the soap over the end of your uncapped valve stem.
bobbyvstrom is offline
post #10 of 13 Old 04-20-2015, 10:15 PM
Austin44's Avatar
Anyone have any thoughts?Scott
Slow leak in my rear tire was so slow that it didn't show up so you'd see it with the tire turned in 8" of water in a tub.
My mechanic neighbor said to pump it up to 75 psi and try again, it wouldn't hurt anything if I didn't try to ride it that way. Sure enough, there was a tiny stream of bubbles from the base of the valve stem. It had dried out and cracked a bit INSIDE the wheel.
Apparently not much leaked out sitting at 40 psi. Under the stress of riding ( acceleration, I need to lose some weight, lousy condition of Chicago streets ) the leak accelerated.
Austin
Austin44 is offline
