Fork Spring Stiffness Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 04-05-2015, 03:23 PM Thread Starter
jurgenk's Avatar
Have a line on some used Race Tech 1.0 springs off a 05 Wee for a good price. For my weight (~200 lbs), these will be stiff according to their spring rate calculator. Couple of questions: I have a 2012 model and will these springs still fit (i.e. are fork diameters the same)? Also, I ride primarily on gravel forest service roads and have not noticed much of an issue with the current suspension set up other than a tendency for occasionally bottoming out on hard hits. Could I expect to achieve a better set up than stock if I installed these springs with a lower weight oil or other "tuning"?
Brad
12 DL 650
00 KLR 650C
jurgenk is offline
post #2 of 12 Old 04-05-2015, 10:23 PM
RichDesmond's Avatar
They will fit, you may have to make new spacers. Rate-wise they're not ideal (0.90s would be), but they will be better than stock. Use 10w oil with them and set the level (air gap) at 150mm.
Rich Desmond
RichDesmond is offline
post #3 of 12 Old 04-05-2015, 10:41 PM Thread Starter
jurgenk's Avatar
Thank you Rich...
Brad
12 DL 650
00 KLR 650C
jurgenk is offline
post #4 of 12 Old 04-05-2015, 11:12 PM
I had my forks rebuild with racetech emulators and stiffer springs. I love that the front end doesn't dive when I brake but they are a bit firmer than I like and the bike doesn't seem to turn as nimble. maybe its just in my head.
OhioRider is offline
post #5 of 12 Old 04-05-2015, 11:28 PM Thread Starter
jurgenk's Avatar
I am looking to do this on the cheap and as most of the FSRs I am riding on are pretty well maintained, the big hits are rare and will leave off the emulators for now. As well, this is only my second bike and front suspension is one of the many areas that I am less then specialized in; as a result, I do not want to get too carried away with my needs. Looking forward to diving in as I have serviced my KLR forks and the process seems similar. I do a fair bit of highway riding, and any improvements would be a bonus, but I have little to compare to as the KLR is the only other bike I have ridden on the street.
Brad
12 DL 650
00 KLR 650C
jurgenk is offline
post #6 of 12 Old 04-07-2015, 12:26 AM
Stromtrooper.com Sponsor
SV Racing Parts's Avatar
Thumbs up Fork Spring Stiffness Question
Hi Brad, unless you have already purchased these 1.0 springs; pass on them because of the weight. At ~200 you really do need a set of 90wt for a great ride. These 1.0 springs are meant for riders north of 255, That is a lot different than 200 lbs.
Be patient, used springs will come up in the weight range that will give you the benefit and ride you are really looking for,
Blair
SV Racing Parts is offline
post #7 of 12 Old 04-07-2015, 01:39 AM Thread Starter
jurgenk's Avatar
Have already bought them Blair, so I will make them work... Might not be ideal, but it will give me a different set up that I can play with. I got 230 lbs when I used their calculator, so thought them close enough.
Brad
12 DL 650
00 KLR 650C
jurgenk is offline
post #8 of 12 Old 04-15-2015, 03:12 AM
to be honest - sell them to someone else and buy some 0.90kg or even 0.85kg one side and 0.90kg on the other.
unless you carry a heavy tank and crash bar bags, they are way too stiff for you - you will just hate it. even if you ride 2 up, its way too stiff for you.
i am 210lbs out of shower these days and i find 0.90kg perfect
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #9 of 12 Old 04-15-2015, 06:15 PM Thread Starter
jurgenk's Avatar
I do carry quite a bit of gear in Aerostich tank panniers but I will try them and if they are too stiff, then will attempt to resell them.
Brad
12 DL 650
00 KLR 650C
jurgenk is offline
post #10 of 12 Old 04-15-2015, 07:10 PM
Set them up with a little less oil, 160mm. That will help a little. If you need a set of instructions PM me your email address.
Rich Desmond
