Vee and Wee Rear shock compatible? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 03-01-2015, 06:57 PM Thread Starter
millwright98's Avatar
can someone confirm if the 650 and 1000 rear shocks are compatible?...have a chance at re sprung and re-valved stock 650 shock that is suited for me and want to put in my '02 Vee... thanks!
2002 DL1000 K2
millwright98 is offline
post #2 of 3 Old 03-01-2015, 07:03 PM
They will fit, but the Wee shock is a couple on mm shorter, sprung lighter, and isn't damped as accurately due to being an emulsion shock rather than having the oil and nitrogen separate like the Vee shock does.
post #3 of 3 Old 03-01-2015, 07:19 PM Thread Starter
I can live with a few MM shorter..the difference will be made up in the lack of sag. the shock in question has been re-sprung and re-valved by Daughtrey's ... to same spec's I would have mine done to.... just wanted to make sure that they would direct swap hardware wise... thanks GW
2002 DL1000 K2
