Conti TKC70 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 35 Old 03-01-2015, 11:51 AM Thread Starter
Toytech's Avatar
Conti TKC70
Greetings all,
I purchased and installed TKC70's. Up close and personal these look great and will likely work out fine. However they do not come with the paint dot to help with balancing. I am having difficulty getting the from tire balanced and it is causing a steering wobble on decal or down hill. Looking for answers anybody?
I don't mind the going and I don't mind the stopping. I absolutely hate the stop and going.
Toytech is offline
post #2 of 35 Old 03-01-2015, 12:20 PM
Scott E. Bonds's Avatar
What do you mean by balancing? How are you doing it? Static or dynamic with a machine? Any tire will balance regardless of a dot, the dot just helps the balance require less weight
Not all tires have a dot.
I like the TKC 70 and was leaning that way for my next set. Continental tires in other types have caused decel wobbles in stroms, so it may be a tire tread pattern issue. Stroms have a steep steering head angle and front tire choice is critical for them.
Hfxoldvolks likes this.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #3 of 35 Old 03-01-2015, 12:23 PM Thread Starter
Toytech's Avatar
I have a Mark Parnes static balancer. It's the wobble that concerns me.
Toytech is offline
post #4 of 35 Old 03-01-2015, 12:33 PM
So, I assume the static balance is OK, that's how I do it. How much weight did it take?
Try this, put 40 -42 psi in it so the tire tread is up on the crown more and see if wobble changes. You may have a steering bearing issue that these tires have magnified.
My strom would not run front Tourance tires because of wobble and they would balance fine.
P.S. - where did you buy the TKC70 and how much were they?
post #5 of 35 Old 03-01-2015, 04:48 PM Thread Starter
Toytech's Avatar
I'll try increasing pressure to see if getting it up on the center decreases the wobble. 5 1/4 oz stick-on weights 3 on one side 2 on the other. Steering head bearings are correctly adjusted. Motosport, Oregon. Too much $298.00/set.
Toytech is offline
post #6 of 35 Old 03-03-2015, 09:20 PM
mattski1's Avatar
I'm about 98% sure I'm going to put TKC70's on my 2012 DL650 in the next 3-4 weeks (been riding on a plugged rear tire for the last 5K miles). I have, however, read enough similar stories from other Strom purchasers that I'm getting a little leery.
What year and model bike did you put the rubber on? I'd appreciate it if you'd keep us up to date on your progress. I'll be following closely.
2012 DL650A Adv.
mattski1 is offline
post #7 of 35 Old 03-03-2015, 10:26 PM
Take the weights off and have a shop spin balance the tire. While you're at it, take a good look to be sure the tire is concentric and the beads are fully set in position.
Not all tires have the colored dots, and not all tire makers use the same code. Usually, if the tire has a red dot, that is the stiff area on the sidewalk and should be matched to the low spot of the rim (tires are not perfectly uniform, and rims are not perfectly uniform). If the tire has a yellow dot, that is the heavy spot that should be mounted by the valve where the drilling in the rim removed metal. If the tire has both a red and a yellow dot, use the red dot at the low spot on the rim. If there are no dots, then the tire might be so uniform that it doesn't need the dots.
post #8 of 35 Old 03-04-2015, 10:38 AM Thread Starter
Toytech's Avatar
Follow up to the original post. Everything is now in proper balance with no wobble at all. Instead of putting all the weights in one spot 180 degrees of the heavy point the weights were divided and placed about 5 inches to either side of that point. It still required 4 1/4 oz weights. With hands off the bars they are rock steady on decel and or down hill.
I also will tell you these are very sticky tires on pavement. I have only ridden long dirt driveways so far. I can say they do inspire confidence on that surface.
I'm a happy guy now.
Toytech is offline
post #9 of 35 Old 03-04-2015, 04:43 PM
mattski1's Avatar
Thanks for the follow-up! I've had very good luck using Ride-On for tire balancing and I intend to use it with the new tires as well. I'll report back in a few weeks.
2012 DL650A Adv.
mattski1 is offline
post #10 of 35 Old 03-20-2015, 01:03 AM
mattski1's Avatar
After having my new TKC70's sit in my garage for the last 10 days, I finally got off my butt, took the wheels off and had the new tires mounted. Just finished putting the wheels back on - haven't taken the bike for a spin yet. Have set tire pressure to 34 front, 38 rear. Will give my first ride report in a couple of days.
Here's some pics of my new shoes:
2012 DL650A Adv.
mattski1 is offline
