Elka spring rates - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 01-27-2015, 10:18 PM Thread Starter
KTM Mike's Avatar
Elka spring rates
There are many threads here discussing how one company's spring rate calculator, or shock builder, or suspension tuner will recommend widely varying spring rates for the same rider.
My question is - does Elka tend to spring on the heavy or the light side?
The reason for my question, is I am considering the purchase of a used Elka. Of course the seller's profile does not line up exactly with mine. If I knew they tended to spring on the heavy side they might work for me. If they tended to spring on the light side - they likely will not.
Related to all that - how broad of a range of adjustment for preload do the Elkas tolerate well? Some shocks tend to get more and more harsh seeming with preload.
No longer a Vstrom Owner - fantastic bike! Now sporting a KTM 990 Adventure
KTM Mike is offline
post #2 of 6 Old 01-27-2015, 10:37 PM
RichDesmond's Avatar
Originally Posted by KTM Mike View Post
...Some shocks tend to get more and more harsh seeming with preload.
More preload = more harshness, that's a hard and fast rule of all suspension tuning.
There's a minimum amount of preload that's necessary, but anything beyond that is bad.
There's more to things than spring rate also, the overall damping profile has as much (or more) to do with the feel than spring rate does.
Bottom line, your question doesn't have a simple answer.
What's the weight difference between you and the guy selling the shock?
Rich Desmond
RichDesmond is offline
post #3 of 6 Old 01-27-2015, 11:36 PM Thread Starter
KTM Mike's Avatar
I agree on the preload comment - learned that setting up race sag on my KTM's for enduro racing.
He and I are about the same weight actually - but I would be riding with passenger a good bit of the time. Other issue is his shock is from a Wee (40lbs lighter bike). Having said all that - might a somewhat undersprung Elka still be better than the crappy old stock shock?
And yes, dampening is yet another topic....
KTM Mike is offline
post #4 of 6 Old 01-28-2015, 03:03 AM
Elka used Eibach spring, whose rate is usually stamped on the spring.
what rate they used would have depend on info supplied by the end user at the time
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #5 of 6 Old 01-28-2015, 07:08 AM
...He and I are about the same weight actually - but I would be riding with passenger a good bit of the time. Other issue is his shock is from a Wee (40lbs lighter bike). Having said all that - might a somewhat undersprung Elka still be better than the crappy old stock shock?...
Well, it would be better than stock, but given all that I'd want to respring it. If the price is good enough that that makes sense, go for it. Otherwise I'd let it pass.
Rich Desmond
post #6 of 6 Old 01-28-2015, 08:53 PM Thread Starter
KTM Mike's Avatar
Rich - I am leaning that way to.
KTM Mike is offline
