Decent tire chuck available?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 01-06-2015, 06:47 PM Thread Starter
Rick505's Avatar
I debated with myself (I always win that way) as to what forum to post this question but does anyone have a suggestion for a good air chuck?? Not an tire pressure gauge as that is another whole thread but the actual chuck?? Perhaps it's just me, and I suppose it is, but I get tired of fighting with releasing air every time I attempt to add air to both the bike and automobile. You know press the generic harbor freight chuck to the tire stem and hisssssssss a bunch of air escapes before one can get it squarely on the stem to inflate the tire. Heck even then it is somewhat a fight getting it on the chuck properly. The stock bike valve is straight (but I do have right angle stems I intend on installing with the next tire change) but even my auto with angled stems is a pain to seal up when inflating.
So is this just a "quit being a wuss and learn to use a generic chuck" or are the actual decent high quality chucks available on the market? Seems mostly an issue with the rubber seal not making good contact with the stem allowing air to escape.
Rick505 is offline
post #2 of 11 Old 01-06-2015, 07:23 PM
randyo's Avatar
I use this
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #3 of 11 Old 01-07-2015, 05:10 AM
At the other end of the scale, check eBay for tyre deflators. Once you've set them up screw them in, wait 30 seconds and the pressure is right.
Pete
PeteW is offline
post #4 of 11 Old 01-07-2015, 11:14 AM
I've used many over the years, and none seem better or worse. Milton is the usual brand, but I've used others. The rubber seal inside any of the chucks does wear out, and then they're harder to seat.
post #5 of 11 Old 01-07-2015, 11:33 AM
Fitty's Avatar
I do know this. You want one that will open and release air even when there is no core in the valve stem. It's much easier to seat the bead of a newly installed tire with the core removed. Most air chucks need to press on the valve core in order to open. The good air chucks have a taper to the release valve that will allow it to open when it contacts the outside rim of the valve stem, even when there is no core in the stem.
Fitty is offline
post #6 of 11 Old 01-07-2015, 12:34 PM
randyo's Avatar
my Snap On chuck works that way, but at $160 may be more than most people want to spend
the gauge in it only reads to the nearest 5psi (20psi min, 160 psi max) but can easily estimate to ˝psi with accuracy when I bother to check with my Accugauge
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #7 of 11 Old 01-07-2015, 01:13 PM
Fitty's Avatar
My cheap one does. I think I got it at Pep Boys. If you look closely at the valve in the chuck you can see the required taper.
Fitty is offline
post #8 of 11 Old 01-07-2015, 03:08 PM
AncientMariner's Avatar
The small hand pumps that are used for charging air shocks, available at bicycle shops and many motorcycle shops, usually have no-loss fittings to prevent pressure loss from the tiny systems when disconnecting the fitting. My local bike shop had units with 300 psi range, not too useful. The motorcycle shop (otherwise identical, I'd say) pricier units are more useful with 60 psi range. They stay sealed until the Schrader valve in the stem has closed.
'01 TTR125L, '01 plated WR426, '00 Super Sherpa, '81 KM100, '80 SR500, '78 XS650, '06 DL650, '10 MG V7 Classic, '12 MG Griso 8V SE, '12 VN1700 Nomad, dearly departed (totalled) '03 DL1000
-John
AncientMariner is offline
post #9 of 11 Old 01-08-2015, 04:36 PM
Supatramp's Avatar
I have never regretted paying higher prices for any of the Snap On tools I have.
Supatramp is offline
post #10 of 11 Old 01-08-2015, 07:24 PM
A Snap-On air chuck is $9.90, and it looks like every other air chuck I've seen except for the brass body.
https://store.snapon.com/Closed-Air-...--P647712.aspx
The Snap-On inflator/pressure gauge at $160 seems less useful for bikes than the Snap-On $88 version with 2 psi increments on the gauge. Both have the dual foot chuck which I don't know even fits a strom with straight valve stems, and if it does, is doing things the hard way. I've used Snap-On, Armstrong, Williams, Proto, Mac, Matco, Wera, Felo, Bahco, Bondhus, and other brands of tools, and Snap-On is the prettiest, sometimes thinner wall, and not worth my money.
