Wee pre-load adjuster turns, doesn't adjust - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 09-24-2014, 02:14 PM Thread Starter
sbeadg's Avatar
The knob is quite stiff but I can turn it and feel the detents. No matter which which way or how much I turn it, the adjuster lines show 4.
Any idea what this is?
'15 Tiger800 XRx
'99 Triumph Thunderbird Sport
'89 Honda NX250
"Why don't I have tattoos? For the same reason you don't put a bumper sticker on a Ferrari."
sbeadg is offline
post #2 of 6 Old 09-24-2014, 02:30 PM
It takes almost 30 clicks lock to lock. How far are you turning it. Adding some lube to the mechanism under the knob will loosen it up. It can get very stiff if not used regularly.
post #3 of 6 Old 09-24-2014, 11:12 PM
The rear preload adjuster is a simple hydraulic jack subject to leaking. It can be repaired.
https://www.stromtrooper.com/maintena...ster-pics.html
post #4 of 6 Old 03-17-2015, 09:17 AM
I did this repair a couple of years ago and it's now leaking again. I'm looking for a shock replacement now.
eddie98 is offline
post #5 of 6 Old 03-17-2015, 09:25 AM Thread Starter
sbeadg's Avatar
There's a Progressive 465 f.s. in the market place (or whatever its called).
'15 Tiger800 XRx
'89 Honda NX250
sbeadg is offline
post #6 of 6 Old 03-20-2015, 02:41 PM
I saw it. I was too late for it.
eddie98 is offline
