Are 0.95's too much for me? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 09-24-2014, 08:27 AM Thread Starter
bassbronco_74's Avatar
Hey everyone, been awhile since I've been on here but I've been spending my summer very being very busy! :mrgreen:
Anyways, I'm leaving tomorrow morning for a 6 day trip to California and back (I know it's short notice but hey why not), and I decided to finally put in my 0.95 Sonic Springs I bought off of someone on here last night. I followed the instructions, and put back in order, spring, washer, spacer, spring, and then the cap threaded back in. I buttoned everything back up and left the preload adjusters all the way up or at 0 and checked my sag and after multiple checks i was right about 33-35 mm total sag. I was shooting for 40~ish because that is what i had set on my stock front springs and also what about my Wee should be.
So some background, last year i flushed the forks and upgraded to 15wt fork oil at about 150mm, and other than that my front suspension is stock (besides the springs and spacers now). Also I did measure the PVC spacers supplied with my springs and they are 4.25 inches (checked with calipers)
One thing I noticed is that the instructions call for one extra washer between my preload adjuster and the spacer than what I had before?
So my question to those of you who know suspension out there is, what should i do? My options as i see them are:
1.) Leave as is and see what happens?
2.) Take caps back off, pull out pvc spacer and put back in stock spacer (stock is slightly shorter than pvc one)?
3.) Take out just the extra washer that was between the spacer and preload adjuster?
4.) Put it back to stock for my trip and fiddle with it later when I get back?
Right now I'm leaning towards #2 to try and reduce the preload by putting back in the stock spacer, luckily it only takes me about 30 minutes or less to open the top of my shocks up.
Help??!
DL650K7
XL1200N (Sold)
bassbronco_74 is offline
post #2 of 11 Old 09-24-2014, 09:06 AM
Assuming 0.95kg spring suitability is within YMMV range of your weight ( u didn't publish your weight), I would just cut the spacer down 10mm and use the adjuster to fine tune your sag.
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #3 of 11 Old 09-24-2014, 09:59 AM Thread Starter
Shoot! I knew I was forgetting something. I'm about 200 pounds geared up to ride.
I hadn't considers cutting the spacer, but I like that idea even more. I would definitely like to have to put some turns on the adjuster so I have to option to "soften" up if I feel like it.
DL650K7
XL1200N (Sold)
post #4 of 11 Old 09-24-2014, 11:46 AM
The original spacers might be just right without the bother of cutting the new ones.
Try 10 wt fork oil, or maybe even home-brew a bit thinner than that. The .95 are on the sporty side for your weight--not bad, but maybe not plush.
post #5 of 11 Old 09-24-2014, 12:22 PM
I'm about your weight fully geared up (180 naked). I've got .90 & 10 wt. with near OE length spacers & 40mm sag. I did have to add some preload, so I'm thinking about putting longer spacers in.
2007 DL 650 with assorted upgrades
Solo is offline
post #6 of 11 Old 09-24-2014, 05:07 PM
Garbage Marc's Avatar
I'm #250 and I have 95's in my bike and they're plenty stiff even at my weight. I'm running 10w with mine and I cut my spacers so that the total length is the same as the stock springs with the stock spacers.
" Do not argue with an idiot. He will drag you down to his level and beat you with experience."
Present Rides
[*]2015 KTM 1290 SA[*]2012 Road Glide Ultra[*]2013 KTM 500 EXC
Garbage Marc is offline
post #7 of 11 Old 09-24-2014, 06:30 PM
RichDesmond's Avatar
Originally Posted by bassbronco_74 View Post
...2.) Take caps back off, pull out pvc spacer and put back in stock spacer (stock is slightly shorter than pvc one)?...
This is the way to go. Essentially, the only parts you replace are the springs. Spacers/washers remain the same as stock.
Rich Desmond
RichDesmond is offline
post #8 of 11 Old 09-24-2014, 06:32 PM
Originally Posted by Garbage Marc View Post
...I cut my spacers so that the total length is the same as the stock springs with the stock spacers.
That's the most common mistake people make. With the stiffer springs you need less preload, i.e. the total spring/spacer length needs to be shorter than stock.
Rich Desmond
post #9 of 11 Old 09-24-2014, 11:58 PM
jokermtb's Avatar
Prolly don't even NEED the spacers.....I'd try em without the spacers, 10wt oil and let er rip
jokermtb is offline
post #10 of 11 Old 09-25-2014, 04:03 AM
You will need spacers (at least for sonic springs length)...
Base on what i used, I second PT Riders assessment that 0.95, though within range, is probably on the sporty side for your 200lbs gear up weight - of course you might like it that way.
I cant remember what the stock spacer length was , but since you know the results of the current PVC spacer, you can measure it and see how it compares with the stock spacer length and go from there.
If i were you, i would aim for a rider sag of 42mm (30% of measured 140mm fork travel) with my fork adjuster in the middle of the adjustment range (about 10mm). This is for touring road rides.
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
