Removing rear tire - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 09-15-2014, 10:45 AM Thread Starter
Mastery's Avatar
Removing rear tire
Can the rear tire on a 07 DL650 be removed when bike is up on the center stand? Or do I need to use a motorcycle jack?
Lighten up, Francis. If you can't take some sarcasm, an Internet forum is the last place you should be.
http://www.JourneyLogbook.com - Easy to use adventure journals
Mastery is offline
post #2 of 10 Old 09-15-2014, 10:46 AM
Yes.......
post #3 of 10 Old 09-15-2014, 11:15 AM Thread Starter
Mastery's Avatar
Thanks greywolf. Wanted to know before starting the process later, since I don't own a jack or rear stand.
Mastery is offline
post #4 of 10 Old 09-15-2014, 12:11 PM
When you re-install
Before you remove the wheel find some shims (I have some various pieces of plywood) that fit snugly under the wheel. Then remove them until time to put the wheel on. Using them to re-install will make it go easier.
Some people just use their feet to hold the wheel up while slipping the axle back in. I like the shims.
One more thing. Make sure the caliper tab is located correctly.
2007 DL 650 with assorted upgrades
Solo is offline
post #5 of 10 Old 09-15-2014, 12:26 PM
V-Tom's Avatar
A 2 by 4 or other board works well to give leverage to raise it. Get one a few feet long and thane you can put something under it to hold it up. Also, if the bike has ABS you should remove the sensor before removing the wheel (at least this is the case on my 2012 DL650.)
..Tom
SMIDSY detailed report.
V-Tom is online now
post #6 of 10 Old 09-30-2014, 06:40 PM
nbsdave's Avatar
along this line-
can the rear wheel be removed using a spool stand?
if so, what/how to do it?
don't have a center stand but do have a spool stand
nbsdave is offline
post #7 of 10 Old 09-30-2014, 07:33 PM
Originally Posted by nbsdave View Post
along this line-
That can work if you actually have spools on the swingarm. You can't support the bike by the axle ends and take the axle out.
post #8 of 10 Old 09-30-2014, 07:36 PM
nbsdave's Avatar
have spools
guess I'll give it a try
will brace the bike on both sides to be sure (try to be) it doesn't tip
nbsdave is offline
post #9 of 10 Old 10-04-2014, 09:25 PM
bwringer's Avatar
along this line-
Yes, it works fine.
bwringer is offline
post #10 of 10 Old 10-04-2014, 11:08 PM
KZDon's Avatar
This thread is helpful
https://www.stromtrooper.com/maintena...de-easier.html
KZDon is offline
