Dialing in the VEE Suspension with ELKA, DMR, and SONIC - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 09-06-2014, 09:35 PM Thread Starter
FLtrooper's Avatar
This suspension thread is on-going with my impressions as the changes are made. I recently picked up a 2005 VEE to be a companion with the WEE at most recently had. My Wife and I took the VEE on a short 3,000 mile trip to test out the new toy. Even after messing with some suspension settings, I quickly realized the VEE needed some work. I weigh just over 200lbs with gear, My wife is 100lbs with gear, and setup I usually have another 50+lbs. My ultimate goal is a safety and a more sporty suspension feeling.
I tried adding some Sonic 0.95 springs and fresh oil. Overall I was impressed with the improvement BUT I knew something was still missing.
I recently decided to reach out to Jaime @ Daugherty Motorsports - Motorcycle Suspension Performance and Modification, to have the fork valving changed. The re-valve should fix the initial softness felt when applying the brakes. I hope to have the forks back in a week or two.
I also recently picked up a ELKA stage 4 rear shock. I sent the shock out to Cycle Mall (certified ELKA suspension shop) in California for a complete rebuild and to have the spring swapped out from 500lbs to a 900lbs per the recommendations of the good guys at Cycle Mall.
I hope to have these components back in the next couple of weeks. I will share my impressions once installed.
Over 40 states, A small portion of Canada, and some of Central America on two wheels! Ed Bargy Track Certified!
FLtrooper is offline
post #2 of 16 Old 09-07-2014, 10:54 PM
Should be pretty good when fully loaded. One up will be very firm, I say, with with 50lbs of gear
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #3 of 16 Old 09-09-2014, 07:41 PM Thread Starter
FLtrooper's Avatar
Yes, and I'm actually looking forward to a firmer ride. I just hope it isn't too firm! Haha
I got a call today from cycle mall and they are shipping back my ELkA, hopefully my forks come back soon from DMR so I can start dialing it in!
post #4 of 16 Old 09-17-2014, 09:08 PM Thread Starter
FLtrooper's Avatar
The ELKA arrived with a fresh rebuild and a new 900lbs spring. I was given word that the front forks we're complete and should be shipping soon.
I decided the install the rear. What a pain the in ass with a SW Motech center stand. I still need to figure out a slick way to mount the adjusters.
post #5 of 16 Old 09-19-2014, 02:34 AM
I installed and removed shocks from my DL1K many times over the years and I never ran into any issues with the centerstand (OEM). What isn't about the SW-Motech stand that is in the way?
Gustavo
Gustavo is offline
post #6 of 16 Old 09-19-2014, 08:40 AM
cameraman's Avatar
I just emailed cycle mall to see about having my Elka rebuilt. How happy are you with their work/customer service so far?
Safety side note:
I can't tell for sure but it looks like you don't have your center stand secured. Any time I ever work on the bike extensively, I strap the center stand to something forward to keep it from folding back and the bike dropping to the ground. I would take a ratchet strap and secure it to one of those jack stands or to the crash bar.
Tom G
Atlana
07' weeeeee!!!
cameraman is offline
post #7 of 16 Old 09-19-2014, 09:01 AM Thread Starter
FLtrooper's Avatar
Gustavo
Perhaps it isn't entirely the Stand but it appeared to give me very little to no movement. Having changed numerous rear shocks before I was expecting a 30 min job but it ended up consuming 2+ hours. I'm now trying to locate the perfect mounting locations for the adjusters. I plan to pick up some square stock aluminum to make a bracket.
Safety side note:
Well the timeline on the ElKA from cycle
Mall was decently quick. I feel like they actually listened to me in regards to setting the shock up and picking spring rate. I am still waiting on my forks from DMR and I just installed the WERKs clutch basket last night so I can't wait to get out and see how she runs!
I hear ya on not trusting the center stand and the straps seem like a good idea BUT if you look at the front jack stands you will notice that they are more dangerous then the center stand haha. Initially this was just a rear shock change and it's has evolved into way more!
I will let you know when the forks come in and I get this on the road.
post #8 of 16 Old 09-19-2014, 09:56 AM
The SW-Motech center stand has a bar across the top that gets in the way while the OEM stand does not.
When I did the Elka on my Wee, taking out bolt #5 gave access. Make sure the #7 washers are replaced.
post #9 of 16 Old 09-19-2014, 10:40 AM Thread Starter
FLtrooper's Avatar
Thanks for the Look Out GW! I didn't replace the washers as they appeared to be in very good shape but I did have a HELL of a time getting them back in. I almost have up and didn't put them back but I tried one more time and got lucky!
post #10 of 16 Old 09-19-2014, 10:45 AM
I meant put them back rather than change them.
