Fork Spring Replacement '02 1K - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 03-24-2014, 08:53 PM Thread Starter
millwright98's Avatar
This may sound like a dumb one but here goes...I have a set of 1.0 Racetech springs on order...
On my '02 1000V, (no spring adjusters) can I just move the handlebars out of the way, loosen the top of the triple tree, remove the fork cap, pull out the stock spring and spacer, replace with new spring and spacer made to the same length as stock and button it back up? or do you have to completely remove and disassemble per the book?...looks do-able my way from the drawings in the service manual? Only 15,000 km on bike and don't want to disrupt seals etc. May suck out oil and change that way, I realize this method doesn't change all the oil. What say those with more knowledge of the voodoo of front suspension ? Thanks, Craig.
2002 DL1000 K2
millwright98 is offline
post #2 of 10 Old 03-24-2014, 09:11 PM
RichDesmond's Avatar
You don't want the new total spring/spacer length to be the same as stock. (That will give you too much static preload with the stiffer springs.)
You don't want to leave old fork oil in there.
No need to separate the tubes or mess with the seals, but you do need to pull the legs off the bike so you can invert the tubes and get all the old oil out. Also much easier to set the fork oil level if they're off the bike.
Rich Desmond
RichDesmond is offline
post #3 of 10 Old 03-25-2014, 08:42 PM Thread Starter
ok..thanks....was hoping to avoid total removal...but what the heck...doesn't seem like winter is going anywhere too soon up here...lol
2002 DL1000 K2
post #4 of 10 Old 03-25-2014, 09:59 PM
madchap's Avatar
Just an FYI. The first time I removed my forks I tried to remove the fender first. After much trying I found out you have to slide one of the forks out before you can remove the fender At least that's how it is on a Wee.
[URL=http://s168.photobucket.com/user/jclovesu247/media/VisitedStatesMap_zpsf76dca46.jpg.html][IMG]http://i168.photobucket.com/albums/u179/jclovesu247/VisitedStatesMap_zpsf76dca46.jpg[/IMG][/URL]
madchap is offline
post #5 of 10 Old 03-26-2014, 12:25 PM
Those pesky nuts inside the front fender can be a pain. I glue them into place with one of the clear, strong polymer glues like Liquid Nails Perfect Glue or a similar product.
post #6 of 10 Old 03-26-2014, 01:16 PM
raYzerman's Avatar
I'd pull the forks and change the oil too. Your new springs/spacer are likely to give you a different oil level, so best start fresh.
As for preload, I'd cut the new spacer for same length, check your sag and if you need to adjust, you can always shorten...... OTOH, RaceTech sends you some extra washers to add some preload if you need it/want it.
raYzerman is offline
post #7 of 10 Old 03-26-2014, 03:07 PM
You want to cut the spacer so that you have about 15mm of static preload on the spring with the fork cap screwed on.
On the '02s, with no preload adjuster, that means the spacer should be just about flush with the top of the fork tube. (With the fork fully extended, of course.)
To double check, measure the depth of the fork cap, i.e the part that goes into the tube. If it's 15mm, then the spacer should be flush. If it's more than that, then the spacer should be recessed into the tube by the amount greater than 15mm. If the cap is 18mm deep, then the tube recessed 3mm.
Likewise if the cap depth is less. If it's 13mm then the spacer should stick up 2mm above the tube.
DON'T start with it the same length as stock. There will be a lot of spring force to overcome to get the threads started (much more than stock) and it makes it easy to cross-thread the caps.
Rich Desmond
post #8 of 10 Old 03-26-2014, 04:23 PM
megaDon's Avatar
I have the same bike and just got Racetech 1.1's and gold valves in. I ended up getting a local shop to do it, his prices on parts were so good it amounted to free labour.
Went down on my strom
I sold my Aprilia because I was broke but spent it all on upgrades for the Strom, ah well...
megaDon is offline
post #9 of 10 Old 03-27-2014, 03:29 AM Thread Starter
Great suggestions and info guys thanks....pretty much made up my mind to pull the forks, pump them dry and do it right...no point in taking shortcuts now
thanks again!
Craig
2002 DL1000 K2
post #10 of 10 Old 03-27-2014, 12:27 PM
Used fork oil that looks like bad mud is normal. I flush mine with solvent (paint thinner) and any cheap, light hydraulic oil (jack oil) to clean them, but Rich says that much effort isn't needed.
